Audi A3 Black Edition Jan 2011
Samboii Nov 28, 2011
  1. Samboii
    Samboii New Member
    9
    I would like to activate the coming home/leaving home lights on my car. I have no auto light switch. I think, having read many posts on here, that i can alter the computer settings to enable this function (i do know that this will mean the lights will be on during the day as well). Can anyone advise me where in the computer, i can find the settings that need to be altered and more importantly what i need to type to make the car do this? Many thanks
  2. TheStreetman
    TheStreetman New Member
    19
    Hi there,
    If you navigate thru the Drivers information system via the switch on the right stalk, you will find the option to check/uncheck the lights options, the coming/leaving home function is located within that menu.
    If your vehilce does not have this function i'm sure your Audi dealer will tech the car to set the function for you.
    Hope this helps. :salute:
  3. rOb_A
    rOb_A Active Member
    1,488
    may sound daft but what does this function do ? :unsure:
  4. Avus Sportback
    Avus Sportback Member
    114
    Follow this link, cominghomelights - Audi Retrofit
    I have the same car as you and did the mod a couple of weeks ago, the mod does not mean your lights will be on during the day, only on when you lock / unlock the car for your predetermined time.
    You will need VCDS to enable the function.
    PS - only check Byte 00 Bit 07 and not 05 as well.
  5. Avus Sportback
    114
    When you unlock the car the headlight come on, (suppose its incase you live in a dark unlit area?) light also stay on after you lock the car.
  6. rOb_A
    rOb_A Active Member
    1,488
    my interior lights come on, should the headlights come on as well then? i to don't have auto lighting
  7. Avus Sportback
    114
    Then you also need to carry out the mod, really simple and quick to do.
  8. rOb_A
    rOb_A Active Member
    1,488
    looked at the mod, looks simple enough but i don't have access to VCDS :shrug:
  9. Avus Sportback
    114
    Someone will help you out unless you travel to Rochdale and I'll do it for you.
  10. rOb_A
    rOb_A Active Member
    1,488
    best place to get repair wire 000 979 009 ??
  11. Avus Sportback
    114
    Audi, about 67p or something
  12. rOb_A
    rOb_A Active Member
    1,488
    cheers Avus !!
  13. Samboii
    Samboii New Member
    9
    Thanks Avus, Makes complete sense. Its nice to know someone with the same car has activated this CM/LH lights. I wasn't sure if we needed the wire or not. Now i know you do! Thanks
  14. Samboii
    Samboii New Member
    9
    Thanks TheStreetman. Avus seems to have the perfect answer. The Audi Retro fit also nails it!
  15. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    569
    149
    43
    Avus do you have the repair wires? Was trying this mod last night with Trups but we didn't install the wire. Also he noted things had changed under the dash on my new car. Do you know where to put the wire on these later models? Also need to double check the coding too, as i'm not sure what was inputted.
  16. Samboii
    Samboii New Member
    9
    Just removed the dash cover as instructed and as Helifella says there has been a bit of a change down below! Any idea were the wire goes as Block H, port 12 isn't there :-(
  17. Helifella
    569
    149
    43
    Hi Samboii,
    Can I ask where you bought the repair wire and how much it was?
  18. Samboii
    Samboii New Member
    9
    My local Audi Garage and it cost £2.12.... but were do i fit it!!!
  19. Helifella
    569
    149
    43
    Thanks, I will wait for someone to tell us before I go and buy one. Hopefully Avus Sportback can tell us???
  20. Helifella
    569
    149
    43
  21. Ash187
    7,478
    735
    new facelift cars have different CE modules, with 3 main big plugs as opposed to the 10 smaller plugs we have in the older cars.
    you need plug C pin 18 if you really want to do the wire route.
  22. Samboii
    Samboii New Member
    9
    So if i fit the wire and alter the coding via VCDS i should have Coming Home/Leaving home lights?
