AUDI A3 B pillar trim.
vw754 Aug 20, 2011
  1. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    Anyone know how to remove the 'b' pillar trim (on the exterior) (outside) drivers side on the 5 door sportback ?
    Also ..........WANTED !
  2. aaa3
    aaa3 Member
    43
  3. Jord
    Jord Member
    280
    Looks so much better in gloss black, anyone know where can get them from?
  4. slade777
    slade777 Member
    763
    A few people have bought them off Stoke Audi. Agree they do look so much better
  5. slade777
    slade777 Member
    763
  6. vw754
    2,329
    58
    better learn french then we all understand :moa:
  7. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Google Translator ..
  8. Alex 3B
    Alex 3B Member
    37
    Looks good but I think I'll just paint or vinyl mine lol
  9. 1inchpunch
    1inchpunch Member
    451
    I think the gloss looks good on the 3 door but it's a bit poorly thought out on the sportback. The fact there's a big matt rubbery bit for the windows either side of the pillar, and the rear triangle has another big rubbery strip running up behind it makes it look a bit like an after thought (probably because it is an after thought).
  10. nally
    nally MPG the new BPH
    2,104
    34
    what do these look like old/ new?
  11. N8
    17,163
    718
  12. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i will be keeping my non gloss ones gives good contrast vs my paint but i can see reason for it on a silver akoya or the like
  13. Deze2014
    Deze2014 smokertoker
    230
    17
    link doesn't work:notworking:
  14. AndyParker
    AndyParker Active Member
    320
    It is over 3 years old unfortunately.
    If the 5 door is the same as the 3 door then you need to drill out the rivets that hold them in place and then put new rivets in with a rivet gun to attach the new ones.
    Rivets are located behind the door seal - pull it back and you'll see them.
  15. AndyParker
    320
  16. Deze2014
    230
    17
    unfortunately mate the thread is for the 3 door model, I have the sportback, by the looks of things there different as at the bottom of the pillar trim when both doors are open I think theres some sort of weather strip over im assuming where the rivits are. Im not going to play about yet as I haven't sourced the both glossy black exterior trims yet, but defo going to do it, think it looks a lot more attractive. theres a triangle bit aswell on both rear door corners of the windows and im assuming il have to get gloss black replacements aswell for them. thanks for the help bud :)
  17. AndyParker
    320
    Yes sorry - I thought there may have been a difference but wasn't 100% sure! Sorry I can't be more helpful than that
  18. mjr901
    mjr901 Guest Gold Supporter Audi S3
    3,595
    1,063
    I've supplied many of these...please use the parts request system and I'll sort you out :)
    Deze2014 likes this.
  19. bhafc78
    bhafc78 Member
    35
    Where is and how do you use the parts req system pls?
