audi a3 auto problems?
jimmytotheh Jul 28, 2013
  1. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
  2. gen.heinz guderian
    1,346
    126
    If the ATF is low or has clutch friction material in it the box will change quite hard when hot.
    Do the revs flare when trying to change from 3rd to 4th? What happens when it is in Tiptronic mode?
  3. jimmytotheh
    jimmytotheh Member
    35
    i see what you mean because thats exactly what its doing. well usually the revs flare more in the lower gears 1st, 2nd and 3rd. once im upto 4th, 5th and 6th its hardly noticable. when i put it into tiptronic its harsh when changing in the lower gears again and it tends to react late and then slam hard.
  4. gen.heinz guderian
    1,346
    126
  5. jimmytotheh
    jimmytotheh Member
    35
  6. Monsoon
    Monsoon Member
    102
    I've been doing a bit of research on this. It looks like the transmission valve body (mechatronic unit) is on its way out. It's a common fault on the older Audi/VW tiptronic and multitronic gearboxes. Apparently Audi in America have extended the warranty on this part to 100,000 miles as it's a known issue, but no such cover here. Do a google search for 'valve body fsi automatic jerk' and you'll see dozens of websites about the problem. If it is this, it's a four figure sum to fix.
  7. jimmytotheh
    jimmytotheh Member
    35
    That's worrying. I'm going to ring Audi tomorrow see what they say. Knew I shouldn't of bothered to get this auto. AUTOMATIC=PROBLEMATIC
  8. jimmytotheh
    jimmytotheh Member
    35
    Car is booked in with Audi tomorrow. Will let you know how it's got on. Fingers crosses
  9. jimmytotheh
    jimmytotheh Member
    35
    had it in at audi on friday. they spent 5 hours on it and basically told me that they cant get to the root of the problem just yet because i need to change my catalytic converter because its basically had its day and its throwing up many error codes. luckily they didnt charge me anything but just said bring it back when you have the new cat on the car. so il be doing that in the coming days. il update as soon as.
