Audi A3 Armrest Fitting
Cruiser89 Feb 8, 2010
  1. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    Right guys...
    I have just managed to buy a pretty much brand new Audi A3 black cloth armrest for a mere £55 including P+P from a contact. Steal of the century I know...
    Three things...
    1. Does anybody have a template (cut out) to fit this armrest.
    2. Is there a part number for the pre cut plastic part of the centre console.
    3. When I do it, would anybody want me to a step-by-step guide on what to do??
    Thanks...
    T
  2. MikeSel^
    MikeSel^ Moderator Staff Member Moderator Team Navarra TFSI Owners Group Audi S3 quattro Manual
    1,128
    574
    Theres quite a few posts with how to's including part numbers etc already on the forum.
    But another how to wouldn't hurt. :)
    Got any more for £55??
    Well done!
  3. Cruiser89
    1,484
    221
    I did use the search facility but it didn't provide much of an insight. Apart from one post about dimensions that were put up!
    Think a defo step by step with clear pics etc would help. If i cant find a template I willing to create one!
    Hmmm i expect so. The guy wanted £100 i offered £50 he threw back £55. Nice.
  4. MikeSel^
    1,128
    574
    Yeah I think there still working on the search facility.
    I have defiantly seen at least one, with photo's of a cardboard template. Not sure on author, I have the memory of a gold fish!!
    Sure someone (NHM?) Will be along shortly to point you in the right direction!
  5. Ads
    Ads License to drive
    8,230
    608
    You can't buy the template seperately, only as part of the armrest kit.... which also includes an armrest!
    I fitted my armrest a few months ago and it was quite a scary time, cutting through my centre console. Although looking back it's quite simple. You have got quite a lot of room for error as the armrest trim covers almost all of the possible area you can cut the hole.
    To help, once the armrest is fitted the measurements are as follows.....
    From the top edge of the rear ashtray to the back of the armrest trim is about 7mm. And from the storage area to the front of the armrest trim is about 10mm.
    From those measurements you should be able to work backwards to calculate where the hole needs to be cut.
    The width of the hole is easy, just make it as wide as the hole for your storage area, maybe a little narrower.
    As for actually cutting the hole, the plastic is pretty soft. I drew with a pencil the place that I was going to cut the hole, drilled a few small holes in each corner using an electric screwdriver with a drill fitting in it, then used the blade of a hacksaw to saw from corner to corner.
    You will need a bolt and a nut to fix the armrest to the car. I used a 25mm M8 nut and bolt. 50mm was too long.
    There is a hole in the bracket that the armrest fixes too but there is no thread in it. It's just a hexagonal hole.
    I found inserting the bolt from the bottom and screwing the nut on the top side was easiest.
    Here's a pic to show roughly where I cut the hole (red), and where the armrest trim sits (green).
    Raiden, aman_ and The Engineer like this.
  6. Cruiser89
    1,484
    221
    Cheers buddy!!!
    Many thanks!!
  7. Cruiser89
    1,484
    221
    just a quick one. How do you pull out the rear ashtray and coin holder??
    Just about to start this mod now :p
  8. Mine clip in and out
  9. Ads
    8,230
    608
    It should just lift out. Open it and kind of pull it out at an angle.
    Let us know how you get on with the armrest fitting.
    Also, DO NOT over tighten the nut and bolt. You could end up cracking the armrest's fixing bracket.
  10. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    No but you can go to a dealer, open the box of an armrest kit, and trace the template onto a piece of paper.
    I am still to fit my armrest I bought several months ago but don't want to f*ck up the cutting. Is anybody local to Northampton and handy with a saw?
    Also I have a bolt, bu no threaded part for the bolt to go into, so is it just a case of using a suitable nut underneth the big metal part? (sorry for using technical words....).
    Pete
  11. Cruiser89
    1,484
    221
    Right guys... Quick update.
    i went into Poole Audi. Spoke to the guy in parts, and he didnt believe me that i bought my Armrest online. he was like you cant just buy it, where did it come from. I said a brand new smashed up 59plate A3.
    He said for me to get the instructions i would need to get the kit. I politely said NO.
    However, my best mates boyfriend works as a mechanic there and he want and got a copy of the full Audi instructions with the official template (Why couldn't the parts guy just do this?). So what i will do is scan it all into the computer and upload
    it on to here for everyone to enjoy?? I will do the template full size so its 1:1 ratio :)
    Will take some photos of the progress as well.
  12. Ads
    8,230
    608
    Here you go mate.....
  13. Ads
    8,230
    608
    That's a touch mate!
    Wish you were fitting your armrest before I did mine.... would've saved me three hours of sweating and staring at my centre console, saw in hand, trying to pluck up the courage to start cutting the hole!
  14. Cruiser89
    1,484
    221
    Well guys its DONE!
    Took me about 90mins once i plucked up the courage to drill in to my brand new car.. Photos are below. I will upload the instructions and the template once i have scanned it all in!! :)
    The Engineer likes this.
  15. cdz
    cdz New Member
    Alrights,
    Any chance you could scan and email me the template?
    Cheers mate!
  16. Pii
    Pii Member
    748
    Great work! Upmost respect to thoses that can hack into their cars!! :o.k:
    Get the instructions uploaded and add this to the FAQ for the next person wanting to do this retrofit. :applaus:
  17. slineaa3
    slineaa3 New Member
    Does anybody have the cutting template to upload?
  18. mike foster
    3,967
    Check post #5 mate. Third paragraph gives dimensions !
  19. Cruiser89
    1,484
    221
    Hey guys!!!
    Sorry I have been away a while!!
    I will try and find the template and instructions, I have them scanned in at 1:1 ratio somewhere!!!
    Anybody know how I can attach a PDF to the thread?
  20. That would be real handy. Just picked up an '07 S3 and would like to get one installed.
  21. NHN
    29,345
    1,719
    Dont even need the template tbh, its fairly obviously just looking at the base where to cut the hole, also there is a hex nut that audi supply for this & its a rivet type nut that requires a specific procedure to get it to hold in position so you can attach the armrest with the proper bolt/procedure.
  22. Matt_
    Matt_ Member
    51
  23. NHN
    29,345
    1,719
    When quoting someone, dont delete the ending [/Quote] or it wont quote properly as per your previous post.
    Also the rivet nut requires a process to fit it properly, as just screwing the bolt in to pull it up isnt sufficient, as it can with use become loose & requires a shed load of effort to get the knackered hex rivet nut out to fit a new one, trust me been there before.
    You have to fit a spare bolt into the hex nut with another nut along the shaft of the bolt, then push this into the car bracket hex hole & whilst holding 1 you have to do up or undo the other, cant recall which way, which then pulls the rivet nut upwards whilst in the armrest bracket attached to car chassis, so it holds fast, then once its tight as hell in the hole, remove the bolt/nut that was just for the fitting of the hex nut & fit armrest with the proper bolt.
    The armrest instructions arent the best, but do detail the process, as usual in not the most legible way lol.
  24. Matt_
    Matt_ Member
    51
    Like that right? ;) cheers fella. I did wonder why it wasnt quoting properly.
    Just my expirience, alot more seem to have struggled.
  25. NHN
    29,345
    1,719
    No worries, all info welcome :)
  26. Cruiser89
    1,484
    221
    Maffers and The Engineer like this.
  27. seano2728
    seano2728 New Member
    Hi chaps, newby to this site but could anybody tell me if i can buy the side circular trims for the arm rest separately? i have brought an arm rest from a breaker on ebay and it has been sent to me without the trims, now the guy is not answering my emails so im stumped! Thanks.
  28. mike foster
    3,967
    Sorry mate - the trims are not available separately !
  29. NHN
    29,345
    1,719
    Where did I see a repair kit for these, urrmmmm
  30. seano2728
    Thanks for the replies, think i might have dropped a clanger then! i have been looking into it and the passat trims look very similar, there on ebay for a tenner so its got to be worth a shot. they will need a little trimming down as the stalk section is longer on the passat but id rather try than fork out for a whole new arm rest! My dads got a black edition (company car) which came with the arm rest as standard, plan is to use his to shape the passat trim and when his goes back to the lease company i may just swap them over! ;-)
  31. nally
    nally MPG the new BPH
    2,104
    34
    how do you change the lid please guys ? part orerd from audi ( due to broken clip) just lid needs changing
  32. NHN
    29,345
    1,719
    Open lid, squeeze (gently) the hinges inward & wiggle out, simplessssss
  33. nally
    2,104
    34
    bloody hell that it ? in that case i may ask the agrage to discount the car for value of the lid and do it myself. is it £90+ vat its a sport back sline leather 1
  34. decal
    decal New Member Team Daytona quattro Audi A4 S-line owners group saloon
    15
    Great work cruiser, I'm going to give this a go. It makes a big difference.
  35. plezz
    plezz Member
    233
    9
    has anyone every tried to retrim the arm rest? i was thinking of taking the lid off and retrimming the dodgy cloth in leather as the rough cloth picks up fluff from my jumper and looks really messy ( i know i'm being a t@rt but still..)
  36. campo1985
    campo1985 New Member
    Do you still have armrest curting template?
    Tried searching and ur guide is great!!!
  37. campo1985
    Also newbie i do apologize, will this fit my 59 plate 5 door dont know what 8chassis etc is help would be appreciated.
  38. Nigelv8
    Nigelv8 New Member
    9
    I believe it will. The 8 chassis means its an A3 then its followed by an L, P or V which shows which mark it is. Yours should be an 8P.
    Im looking for that template as well. Have printed off the fitting guide and it looks way too big.
