Audi A3 8V Reverse Camera (High) DIY Retrofit guide!!
There are 2 horizontal metal supports that become visible once the glovebox is out. One will probably have a tracker on it, the other is perfect for the module.
As @RB_172 has said. There are mounts tucked up on each side of the glovebox. We zip tied ours up to these. Just make sure they are clear of any obstructions and on the right hand side there is a pipe which gets very hot. So be cateful of this.
Jungle
Reactions: pns2007 and DJAlix
As an FYI, the new Face Lift Reversing Camera is a self-contained unit i.e. the camera and control module are now a single unit :)
Ab3a724b 146b 42f0 984b 114620683ada
Reactions: Nic00, Audigit, airbus319 and 2 others
Anyone know where I can get the reverse cam low from? I'm good at parking just not gauging how far car is behind when parking in tight spots
Oh I see...do remember you telling me this any idea where I can get one?
Have seen 3rd Party copies on eBay but they all have Chinese display text. Am sure a google will turn up some results. To be honest for the difference in price I would just go for the High, you get an AUX Video-In also.
Would one for an 8p RNSE work for my 8v?
Never looked in to it to be honest.
Reactions: jungle650
OK fella's, I've got most of the trim out of the boot area and installed the camera, working on the mmi unit, I can't get these bugga's out! They look so easy but don't wanna force. Any help Please?
You just slide out the clear bits (only a few mm) and push down on them a bit to release it... then pull the plug itself.
Reactions: jungle650, rasA4, pns2007 and 1 other person
Hi Guys (its me again!!)
Got all wiring done and camera now installed.
I am unable to access 5F> information Electronics. I get "cannot be reached 0100". I have gone through and cleared the faults, some keep coming back.
Any help again please?
@RB_172 @DJAlix
@RB_172 @DJAlix
Check all cables / wireless my to the rear of the MMI unit, make sure all are connected and none damaged.
Could you attach an autoscan?
Reactions: pns2007
can you scan other modules?
we had a similar problem didnt we @DJAlix ? end up turning on the engine and it all started working as normal.
Reactions: pns2007
OK thanks for the replies. Checked and re-affirmed connections.
Had a drive to the shops to get some gin (I need it after 12 hours on this!)
Came home had a bit of tonic with it and re-scanned. Now only have 2 faults with camera module and guess what it works.
After I changed the coding to that of yours @DJAlix in the write up.
My scan :-
Monday,29,August,2016,19:28:50:20670
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WAUZZZ8V3G License Plate:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 22 42 44 52 55 5F 6C A9 BB BC
VIN: WAUZZZ8V3G Mileage: 16441km-10215miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXC) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1900122426010B2004
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TFS0208V0906259F 001004
ROD: EV_ECM20TFS0205G0906259F_VW37.rod
VCID: 438F77EBCAC5665AFD-8016
No fault code found.
Readiness: 1010 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62545000000477
Coding: 32F193A254252A6F017A070541CA694CC92A5480E08296F6024100788008
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 79F3D503F889EC8AE7-802C
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000732031
Coding: 03100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 336F272B9A65D6DA6D-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 1B5886C7000000000001
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061525800517
Coding: 07040A46C24122F503844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_VW37.rod
VCID: 0913A5C3A869FC0AF7-805C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150826 042 0580
Serial number: 150902133600
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 20634134
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Component: E1 - LDS MQB H05 0032
Serial number: 22 05 2015 00000742
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY152160ZRH
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000062910690
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331525705399
Coding: 0030150001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_VW37.rod
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 012 0361
Serial number: 003M2R12RCHR
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4B9F5FCBE295AE1A05-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 001 509 15
Component: SideSensor_Df 001 0887
Serial number: 3576700000096680761S
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 509 15
Component: SideSensor_Pf 001 0887
Serial number: 35867000000DA580761-
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 209 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502A51D25F722222
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 209 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502B91D1B5D33029
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 400 808 15
Component: FrontSensor_D 001 6149
Serial number: 35565029B1D1B624F17L
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 309 15
Component: PedP_Sensor_D 001 6149
Serial number: 2286502AD1C1EFA2435T
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 309 15
Component: PedP_Sensor_P 001 6149
Serial number: 2296502A91D1B6245327
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 408 15
Component: PedP_Sensor_C 001 6149
Serial number: 2306502BF1CF1D33E24Q
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 EH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 11091504220637
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 040DB4F78F4BA16284-8050
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 972 A HW: 8V0 920 972 A
Component: KOMBI H03 6420
Coding: 27AD08022B8026000101EE001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 3C7D0C17B73B19A2BC-8068
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003927075
Coding: 030100043F085A005B000268080B00000001010000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear.rod
VCID: 75EBD933D49188EA83-8020
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 21 08 2015 F0051322
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001509090596
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00027.07.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_VW48.rod
VCID: 4A915ACFEDEFB7123E-801E
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 310815BHU01493
Coding: 001C8A205001040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_VW37.rod
VCID: 39731503B8092C8AA7-806C
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 030915BI216307
Coding: 001C82205001040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428172EFD5DF6F52F6-8016
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 01AE000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 020 J HW: 8V0 035 020 D
Component: MU-H-ND-EU H45 0404
Serial number: A305I0F7551506
Coding: 01730301FF00000021111101000A00002F00020701000100DE
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_AU37.rod
VCID: 3261222F657FDFD266-8066
Data medium:
Subsystem 1 - Part No SW: V03 959 800 Q HW: -----------
Component: ECE 2015/2016 --- 0122
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY203X9J
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 K HW: 8V0 919 614 K
Component: ControlUnit_H H81 0816
Serial number: C1000023051500040036
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 1010
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300012201000300
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAAU914.rod
VCID: 306528276B73EDC210-8064
2 Faults Found:
10489856 - No Basic Setting
B2010 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Mileage: 16441 km
Date: 2016.08.29
Time: 18:58:13
passive
13705496 - Databus
U1121 18 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 28
Mileage: 16441 km
Date: 2016.08.29
Time: 18:58:13
passive
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 150827200813
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 7DFBC113ECA1D0AACB-8028
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 040915BI403649
Coding: 000C82204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 458B69F3C4F1586AD3-8010
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 040915BI404923
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 04:30)--------------------------
Thanks again
Thanks again
Great Stuff!
The two errors which you have:
  1. 10489856 - No Basic Setting - This will not affect the camera's operation. In order to clear this the camera will need calibration with a special VAS tool kit.
  2. 13705496 - Database U1121 18 [009] - Missing Message - This is a CAN BUS Communications error, possible wiring issue there I think.
Next time your car goes in for a service mention the camera calibration, Audi normally do this for free if the car is in for other works :)
Reactions: pns2007
Great Stuff!
Thanks @DJAli
Camera all appears to be working fine, if there was a can-bus wiring issue would this affect the camera in any way. Could you suggest anything, I've checked wiring and soldering is fine. Been out for a drive tonight so shall re-scan tomorrow.
cheers
Thanks @DJAli
cheers
If there was a Wiring / Layer 1 issue with the CAN Hi / Low then communication with the camera module would be interrupted and it would not be working properly. It could be an intermittent issue, brake in a wire, or maybe a bad join / pin not seated in it's connector properly. I would monitor it for a few days and see how you get on with using it. If you can, before you drive the car again:
  • Autoscan and save
  • Clear All DTCs
  • Un-Tick Display Freeze Frame
  • Autoscan again
After doing this only "current" issues should be displayed, like the Basic Settings DTC. UDS modules like ours can be a bit too aggressive when displaying historic issues and can falsely report issues also.
Monitor for a few days and let us know how you get on.
Reactions: pns2007 and jungle650
Hello everybody.
Comrade asked for help with installing the camera on his car Audi A3 2015 .
We bought the camera and 5Q0907441A unit .
I'm all set up and connect , but ....
There was one problem - I can not encode unit 5F .
I have all the software VAS PS, VCP, Odis, VCPS - but I do not know how .
Help me please. For 3 weeks I read online , but have been unable to find the information .
This link "Audi A3 8V Reverse Camera (high) DIY Retrofit Guide (click here to download pdf)
to open the password is: audi-sport.net"
does not work .
If it contains the necessary information to me - please send me an e-mail (justdoitua @ gmail . com - remove spaces)
Thank you
So you have been able to code your 6C unit without issue but you are having problems trying to code 5F? What error message are you getting?
Yes, i have problem only with 5F.
I have only one error in the block 6C - not calibrated camera. But this is no ploblem - im fixed this later.
The problem is that when reverse gear is no image .
If you turn off MMI and turn on the reverse gear - when you turn on MMI for a few seconds a picture with the camera , but then started MMI , and it disappears .
You need to make sure you have the following configured:
5F
  • (21)-Vehicle function list BAP-VPS_0x0B - activated
  • (22)-Vehicle function list BAP-VPS_0x0B_msg_bus - Comfort database
Then Reset the MMI.
Actually, reading your post again can you please confirm how you have everything currently coded and possibly post an AutoScan.
I'll check .
And can it be that these channels are not available ?
I've read - that must somehow activate 5F cell block ?
And in the instructions from Kufatek - there is a point - he too is necessary to me ?
I'll check .
Do you not have rear parking sensors?
This is a scan of the machine .
But I did before activated 6C .
VIN: WAUBFGFF5F Номерной знак:
Пробег: 7524km-4675mi Номер заказ-наряда: Audi A3
Шасси: FF (5Q0)
Список: 01 02 03 08 09 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WAUBFGFF5F Пробег: 7524km-4675miles
01- Электроника двигателя -- Статус: OK 0000
02- Электроника КП -- Статус: OK 0000
03- Электроника тормозной системы -- Статус: OK 0000
08- Электроника кондиционера / отопителя -- Статус: OK 0000
09- Блок управления бортовой сети -- Статус: OK 0000
15- Подушки безопасности -- Статус: содержит неисправности 0010
16- Электроника рулевой колонки -- Статус: OK 0000
17- Комбинация приборов -- Статус: OK 0000
19- Диагностический интерфейс шин данных -- Статус: OK 0000
22- Электроника полного привода -- Статус: OK 0000
42- Электроника двери водителя -- Статус: OK 0000
44- Усилитель руля -- Статус: OK 0000
52- Электроника двери переднего пассажира -- Статус: OK 0000
55- Корректор фар -- Статус: OK 0000
5F- Электроника информирования -- Статус: содержит неисправности 0010
BB-Door Rear Drv -- Статус: OK 0000
BC-Door Rear Pass -- Статус: OK 0000
Адрес 01: Электроника двигателя (J623-CNTC) Label: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Компонент: 2.0l R4 TFSI H13 0005
Ревизия: --H13---
Кодировка: 0A1D00124426000F2000
Мастерская #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C5CF8A94723E82350-8078
Неисправности не найдены.
Готовность: 1110 1101
Адрес 02: Электроника КП (J743) Label: 0D9-927-770.clb
Part No SW: 0D9 300 012 K HW: 02E 927 770 AQ
Компонент: DQ250-6A MQB H53 4515
Ревизия: 05853104 Серийный номер: TFK01502151298
Кодировка: 0014
Мастерская #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1E382261019F0AB3CE-804A
Адрес 03: Электроника тормозной системы (J104) Label: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Компонент: ESC H42 0610
Ревизия: 00000000 Серийный номер: 60605000000129
Кодировка: 13FF6A9234220A6C017B030881C729C8562C5080C08194B4024100588208
VCID: 4894A439F39B240354-801C
Адрес 08: Электроника кондиционера / отопителя (E87) Label: 8V0-820-043.clb
Компонент: AC Automat H13 0060
Ревизия: 20027000 Серийный номер: 00000000581050
Кодировка: 03000014010000000000000000001400
VCID: 336EE3D59A1DB7DB11-8066
Адрес 09: Блок управления бортовой сети (J519) Label: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Компонент: BCM MQBAB MNA H18 0137
Серийный номер: 01011504800768
Кодировка: 04141A46C04122F541C04004511007000000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
VCID: 79F211FDF8F18D8B9B-802C
Подсистема 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Label: 5QX-955-119-V1.CLB
Компонент: WWS371 150221 042 0585
Серийный номер: 150227003317
Кодировка: 0A47F7
Подсистема 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Label: 8U0-955-559.CLB
Компонент: G397_RLFS H06 0002
Серийный номер: 23740015
Кодировка: 00006C
Light switch:
Подсистема 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Компонент: E1 - LDS MQB H05 0032
Серийный номер: 10 12 2014 00000318
Alarm horn:
Подсистема 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Компонент: Sirene, DWA 004 0311
Серийный номер: 00000000000061786677
Sun Roof:
Подсистема 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Компонент: J245 PS73.404 H03 0004
Серийный номер: 0000FST0005N67500000
Кодировка: 101F00
Адрес 15: Подушки безопасности (J234) Label: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Компонент: AirbagVW20 009 0825
Серийный номер: 003GCR01G885
Кодировка: 9DCCFCC0000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
VCID: 4796A705FE852B7B5D-8012
Belt Pretensioner left:
Подсистема 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Компонент: BeltPretRevFL H36 0350
Серийный номер: 34178311B27021571050
Кодировка: 333135
Belt Pretensioner right:
Подсистема 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Компонент: BeltPretRevFR H36 0350
Серийный номер: 34178312B27021571008
Кодировка: 333135
Occupant Detection:
Подсистема 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Компонент: BF-Gewichtss. H10 0046
Серийный номер: 6940000Y150001ATV90A
Кодировка: 303139
Подсистема 4 - Part No SW: ----------- HW: 480 002 002 15
Компонент: SideSensor_Df 001 0887
Серийный номер: 35700000000DB295D21S
Кодировка: 2D2D2D
Подсистема 5 - Part No SW: ----------- HW: 480 002 405 13
Компонент: SideSensor_Pf 001 0887
Серийный номер: 358000000006F4812D0M
Кодировка: 2D2D2D
Подсистема 6 - Part No SW: ----------- HW: 480 401 102 15
Компонент: SideSensor_Dr 001 6149
Серийный номер: 3510002C7198E152224Z
Кодировка: 2D2D2D
Подсистема 7 - Part No SW: ----------- HW: 480 401 402 15
Компонент: SideSensor_Pr 001 6149
Серийный номер: 3520002AD1993FB31359
Кодировка: 2D2D2D
Подсистема 8 - Part No SW: ----------- HW: 480 400 801 15
Компонент: FrontSensor_D 001 6149
Серийный номер: 3550002991901DA540A0
Кодировка: 2D2D2D
Front Sensor Passenger:
Подсистема 9 - Part No SW: ----------- HW: 480 400 801 15
Компонент: FrontSensor_P 001 6149
Серийный номер: 35600029B1901DA463B8
Кодировка: 2D2D2D
5 Найдены неисправности:
9439258 - Пиропатрон преднатяжителя ремня заднего сиденья со стороны ПП
B1008 1A [137] - Сопротивление слишк.низкое
Индикатор неисправности ВКЛ - Подтверждено - протестировано после удаления записей
9440539 - Пиропатрон 2 преднатяжителя ремня водителя
B100D 1B [137] - Сопротивление слишк.высокое
9438747 - Пиропатрон преднатяжителя РБ водителя
B1006 1B [137] - Сопротивление слишк.высокое
9439003 - Пиропатрон преднатяжителя РБ переднего пассажира
B1007 1B [137] - Сопротивление слишк.высокое
9441051 - Пиропатрон 2 преднатяжителя ремня переднего пассажира
B100F 1B [137] - Сопротивление слишк.высокое
Адрес 16: Электроника рулевой колонки (J527) Label: 5Q0-953-549.clb
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Компонент: Lenks. Modul 002 0110
Ревизия: -------- Серийный номер: 25021508490788
Кодировка: A018
VCID: 7CFC08E9F7C3B8A380-8028
Адрес 17: Комбинация приборов (J285) Label: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 971 D HW: 8V0 920 971 D
Компонент: KOMBI H02 4292
Кодировка: 0BF418092B80D7050200E8001800000000000000
VCID: 3E78C2E1A15F6AB3EE-806A
Адрес 19: Диагностический интерфейс шин данных (J533) Label: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Компонент: GW MQB High 212 2203
Ревизия: -------- Серийный номер: 21021510800019
Кодировка: 0101000830085A005B00020C180B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti.rod
VCID: 72E026D1A587FED3DA-8026
Alternator:
Подсистема 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Компонент: E221 - MFL H02 0014
Серийный номер: 17 02 2015 C0055727
Адрес 22: Электроника полного привода (J492) Label: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Компонент: Haldex4Motion H52 7082
Серийный номер: HA1-00013.01.15
Кодировка: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
VCID: 4688AA01F98F3273A6-8012
Адрес 42: Электроника двери водителя (J386) Label: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 D HW: 5Q0 959 393 B
Компонент: TSG FS 020 0028
Серийный номер: 140215BBD18795
Кодировка: 00100F204000048000000002
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
VCID: 4084BC19DBAB1C439C-8014
Адрес 44: Усилитель руля (J500) Label: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Компонент: EPS_MQB_ZFLS 126 1061
Кодировка: 0102
VCID: 438EB315CABD075B81-8016
Адрес 52: Электроника двери переднего пассажира (J387) Label: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 D HW: 5Q0 959 392 B
Компонент: TSG BFS 020 0028
Серийный номер: 150215BBE06213
Кодировка: 001007204000048000000002
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
VCID: 3F86BFE5A65563BBE5-806A
Адрес 55: Корректор фар (J431) Label: 5Q0-907-357.clb
Компонент: LWR-ECU 005 0080
Ревизия: -------- Серийный номер: --------------
Кодировка: 012A000101000000
VCID: 75EA1DCDD4E9E9EBFF-8020
Адрес 5F: Электроника информирования (J794) Label: 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 047 B HW: 8V0 035 047 B
Компонент: MU-H-NS-US H43 0394
Серийный номер: A052B0FB005189
Кодировка: 01730101FF0A000021220001041A00002F000205010001047E
Мастерская #: WSC 00028 028 00001
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
Data medium:
Подсистема 1 - Part No SW: V03 959 800 SS HW: -----------
Компонент: NAR 2015 --- 0035
Серийный номер: --------------------
Подсистема 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Компонент: DU High H49 0014
Серийный номер: AUZ8Z9EY202KXG
Подсистема 3 - Part No SW: 8V0 919 614 K HW: 8V0 919 614 K
Компонент: ControlUnit_H H81 0816
Серийный номер: C1000014111400030355
Подсистема 4 - Part No SW: V03 959 800 EG HW: -----------
Компонент: Gracenote --- 3006
1 неисправность:
2563 - Навигационная система
B126C F1 [009] - отсутствует база данных навигационной системы
Адрес BB: Door Rear Drv (J388) Label: Не найден
Part No SW: 5Q0 959 395 D HW: 5Q0 959 395 B
Компонент: TSG HFS 020 0028
Серийный номер: 040215BB317165
Кодировка: 000007204000048000000002
ASAM Dataset: EV_DCURearDriveMINKLO 006003
VCID: 4280B611D5A70E538A-8016
Адрес BC: Door Rear Pass (J389) Label: Не найден
Компонент: TSG HBFS 020 0028
Серийный номер: 040215BB31713B
ASAM Dataset: EV_DCURearPasseMINKLO 006003
Конец------------------------(Elapsed Time: 04:31)-------------------------
Шасси: FF (5Q0)
Ревизия: --H13---
Кодировка: 0014
Кодировка: 0A47F7
Кодировка: 00006C
Light switch:
Alarm horn:
Sun Roof:
Кодировка: 101F00
Кодировка: 333135
Кодировка: 333135
Occupant Detection:
Кодировка: 303139
Кодировка: 2D2D2D
Кодировка: 2D2D2D
Кодировка: 2D2D2D
Кодировка: 2D2D2D
Кодировка: 2D2D2D
Кодировка: 2D2D2D
Кодировка: A018
Alternator:
Кодировка: 0001
Кодировка: 0102
Data medium:
1 неисправность:
Really need to see a current scan and how your 5F VPS channels are set.
Good. I meet up with a friend and make a new scan.
Thank you
P/S.
And if there 5F block these channels (21-22 VPS) - what to do ?
  • Autoscan and save
  • Clear All DTCs
  • Autoscan again
A bit late on this but I bought a new soldering iron and re-soldered the canbus hi and low and shrink wrapped. Only error code is the camera calibration.
Before ordering the parts I phoned Audi parts and they said this could not be done lol.
The loom included with the kit was prepared for fitment in the front foot well. I tried everywhere around the glove box to position the module but it would not fit. I had to site it in the footwell with double side tape against the inner wing.
I sent the loom down the passenger side of the rear hatch, I sprayed silicone down the gator and put electrical tape around the wire coat hanger and loom contacts and it went through like a knife in butter. I had about a metre of the loom spare which I had to double back along the sil.
Well chuffed with this mod. thanks all for your help.
Reactions: DJAlix and jungle650
Hi.
I still did it .
Channels:
( 21 ) -Vehicle function list BAP-VPS_0x0B - activated
( 22 ) -Vehicle function list BAP-VPS_0x0B_msg_bus - Comfort database
They were active , but it did not give .
Still helped guide from Kufatek that I could find .
It was necessary to activate the display of parking sensors and all , everything worked .
Comrade very happy .
Thank you.
P.S. See the picture in my post #106.
Reactions: DJAlix
Greetings from the US!! Let me start with expressing my gratitude for your great guide - spending the time to create it in such details and with so much priceless information. Inspired by it I had purchased the camera, the control module and wiring harness and had installed all on my Audi A3 8V (sedan). I took my time and did the installation over the weekend. It followed pretty much what you have outlined except the fact that the fuse box in the left hand drive US cars is under the steering wheel. I had some initial issues with the connections to the CAN gateway (had switched the High and Low wires), but now it seems all is connected properly and my VCDS can see the camera control module and the rest of the MMI is working as it was set before the camera installation.
Unfortunately as with others as I saw in the forum when it came to programing the camera control module I got the:
Coding rejected
Error 31: Request out of range
error.
Tried using the combination of codes from the rest of my modules (on the line with Shop# WSC) - 06385 790 00016 in my case, but it didn't make any difference. I read that perhaps VAG CAN Pro (VCP) is needed for the parametization of the new virgin module and ODIS VAG for the configuration, but not sure anymore. I was able to add the 6c module to the CAN gateway as described in the guide, but in the Adaptation even though I found 108 I could not set/see Node_0x6C (maybe I can't get it and doing something wrong). Similarly for the 5F Adaptation the numbers for the BAP-VPS* were different (not 21/22 as described in your guide). This brings the conclusion that the setup between the US and the UK models is probably different. Not sure what else, but I hope somehow I can make it work if I manage to program the camera control module. It is where I am stuck for now....
I haven't been to my Audi dealer yet, but kind of expect that they will just tell me (politely) to get lost so my hope is that you guys with all your experience can help me. I am attaching the latest VCDS scan I just made. You can see the 5F errors... I wonder why deactivated satellite radio is listed as fault and I am not sure on those other 2 ...I did some of the VCD modes I saw in the DjAlix guide (the Lap timer, Sweeping instrument Needles, the passenger mirror tilt when reverse) and all worked... except the oil temperature, which I disabled back as it was. I also did the changes to the BAP-VPS* there in the adaptation as I mentioned above (the second was already set).
For the backup camera you see:
Coding: 007300022001000300
Shop #: WSC 00000 000 00000
The coding came with the module as I received it - it has no Manufacturer set (the first bit) and some other settings are missing and as I cannot program it all the faults are probably explainable. Wanted to attach the latest scan, but went over the character limit. I can't find another way to attach a file, except as image so I converted the log to images and attach it this way.
Thanks for taking the time to review and hopefully come up with some ideas to try .
Regards
Emil
Coding rejected
error.
Regards
Emil
It's late so not gonna look at the additional errors at the moment but I can see straight away that your 6C module is going to need parameterisation in order to get it working, something which VCDS cannot do. You are going to need someone who has VCP and the Flash Add-On. They will also need access to Audi erWin to be able to download the official firmware. Once up and running ODIS is the only tool which can calibrate this camera module at the moment, but I would not worry too much about this as the camera and module will work fine without it and 9 times out of 10 Audi will do this for you when your car is next in for a service :)
I would not worry about adaptation channel numbers as they will change between markets and revisions.
A good number of people have sent their modules over to me so I can resolve the issues which you have, code and then post back. More then welcome to drop me a PM.
Reactions: T-800 and airbus319
Hello DjAlix,
One question, all the camera modules that you can buy in internet, i.e car-equipment, comes without parametrization?
Regards,
Mike.
Enviado desde mi iPhone utilizando Tapatalk
Hello DjAlix,
Regards,
Mike.
No, not all.
It would seem that there are many used modules flooding the market and a large % of these have not been re-flashed / initialised correctly, meaning that applications like VCDS cannot code or adapt them.
I know a few people who have sourced modules from eBay etc and had not issues at all.
