Audi A3 8V Passenger Mirror Reversing Dip
frazzeld Jun 13, 2013
  1. frazzeld
    frazzeld Member
    138
    21
    I called in at the Audi dealership to ask about the passenger mirror dip when the car is put in reverse....they said its only available with the folding mirror package
    Has anyone managed to succesfully code the reversing mirror dip on the 8V? found a link on youtube
    stemei.de .VCDS Codierungen .Codierungsservice .Webdesign - Stefan Meier - Beifahrerspiegelabsenkung - VCDS Codierungen, Webdesign
    You are here: Coding> Audi A3 8V> passenger mirror reduction
    Passenger mirror reduction in reverse
    In the front passenger door control unit, you have the option of the Audi A3 8V to activate the passenger mirror reduction. Thus, it is automatically lowered when reverse gear is selected and the mirror on the passenger side mirror of the passenger side.
    The following coding is used:
    Select STG 52 (Türelektr. Pass.)
    Long STG coding -> function 07
    Byte 04
    Enable bit 2
    Enable bit 3
  2. sidtec
    sidtec New Member
    9
    Hi
    Has anyone tried this yet?
    I pick up my ex-demo car tomorrow and it hasn't got folding mirrors :(.
  3. frazzeld
    frazzeld Member
    138
    21
    Yes it works as above code
  4. rcnacura
    rcnacura Well-Known Member
    458
    313
    I wonder if you can tell the car that you have power folding mirrors (when you don't) and this will work. I'll try tomorrow and see if it works (hoping) as I didn't get my non-folding mirrors to work.
  5. Schizophonic
    Schizophonic Well-Known Member
    770
    378
    I've got the standard wing mirrors and I've done this on my car. You have to set this in VCDS but also switch to the passenger mirror and set the angle of which you want the passenger mirror. The car needs to learn the angle and it should work.
  6. rcnacura
    458
    313
    How do you do this? I noticed that there was a 90% already set, however I didn't know how to make the mirror learn. Can you tell me the steps? Thanks in advance!
