Audi A3 3.2 DSG Quattro S-Line - Rear Driver Side Shock Absorber 'Issue'
GavinM Jul 31, 2012
  1. GavinM
    GavinM New Member
    10
    On my Audi A3 3.2 Quattro S-Line (2005 05 registered, roughly at 93k miles now)... Ive recently heard a noise from the driver side rear wheel, most noticeable when entering the estate where I live where I slow down to about 15mph to navigate speed humps. Upon further inspection, Ive noticed what is best described as some sort of solid ring of carbon/concrete-appearing substance. The noise I hear occurs when I go over any sort of roadbump/sleeping policeman etc (as this part moves up and down the shock shaft).
    My questions on this are;
    1. is this dangerous ?
    2. is this expected over a lifetime of a shock ?
    3. will this have reduced the effectiveness of the shock/suspension ?
    4. should I get this immediately addressed ?
    5. if above is true, do i need to replace both rear shocks ?
    It is important to note that the car still drives fine, and the balance of the car still appears fine (given the age of the car). Im just concerned this is not meant to happen, and may cause further damage down the line...
    Some folks comment on this when I posted this in a forum I frequent far more often than here (a AV forum BTW), and they came up with the following points (hope they don't mind me copying wholesale here)
    1. Noisy rear shocks were very common on early A3s and modified shocks were made available for anyone complaining. The noise was best described as sounding like a rubber ball inside a plastic bottle. Perhaps yours missed the modified shocks, maybe it's just down to mileage. Personally, I wouldn't worry too much about replacing shocks in pairs if money is tight and only one is faulty.
      It's unlikely you'd notice any difference outside a race track. But if money isn't a problem, go for a pair. I also wouldn't necessarily bother with Audi shocks, I'd go for good quality aftermarket brands. No point paying Audi mark-up for something they've outsourced themselves!
    2. Looks like part of the bump stop.
    As a FYI, the other side rear shock looks like this
    Has anyone with a 2005/2006 A3 8P had this issue before, and did you go through dealer to get modified shocks, or would this be resolved by adding a bump stop, or go another way?
    Thoughts?
  2. infernalzen
    infernalzen New Member
    29
    looks like some bizzare material has built up on your gaiter +when the gaiter moves, it been rubbing against the arch :(
    can you remove the build up with a knife/pliers? trying not to damage the gaiter...
  3. andy1010
    andy1010 Member
    30
    I know this is an old post but did you sort this out I have had the same issue? To stop the knocking I've cut the metal off but need to know if i need to buy a new shocker or can I buy the mount?
    Has this happened to anyone else?
  4. discostu49
    discostu49 Active Member
    598
    132
    43
    They are bump stops nothing serious but can get highlighted at mot time they are cheap to replace just a rubbish job to do as you Jack the car up remove wheels so on and so on
  5. andy1010
    andy1010 Member
    30
    The only problem is the plastic part that goes over the shocker is loose, I don't want the stuff off the roads going down there
  6. fateman
    fateman Member
    58
    I came across the same problem and since the shock absorbers are in good condition I sorted it out with couple of (read four:)) cable-ties.
