Audi a3 2ltr tdi manifold flap
Jonesy76 Apr 21, 2014
  1. Jonesy76
    Jonesy76 Member
    35
    Hi all had a engine management light on and run a scan and It said manifold flap ground , took manifold flap off and it was stuck should it move freely and will running my car with this fault do it damage and where is best price to get this part thanks for reading .
  2. dancupra225
    dancupra225 Active Member
    667
    25
    I have one sitting at home bud if needed
  3. Sevv
    Sevv Pushing the limits..
    1,324
    120
    usually anything stg 2+ they remove the manifold flaps but you need the manifold off...buy it of dan you'll be fine its no biggie i wouldnt think its just cold starts will be a problem if memory serves me right
  4. dancupra225
    667
    25
    Is it the egr flap motor bit your after ? As allard kit deletes that motorsport one
    I have two now as just done roadsport kit on my a3 the other day
  5. Jonesy76
    Jonesy76 Member
    35
    The only thing that's bugging me is the engine management light on because of manifold flap I have cleared it with vag tech but it keeps coming back on because of it !!
  6. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    If it is the intake manifold flap or anti-shudder valve, than you have to change it. It can't be repaired and the EML won't go away.
    You can do fine with that flap broken but in case of turbo failure, when the oil will get into the intake and into the engine, you won't be able to shut it off and will get ruined.
    That valve helps shut off the engine smoothly and to shut it off when goes on oil.
    Also you should check the fuses. Ussually when the valve brakes it also buns one or two fuses. I don't remember which ones.
  7. Jonesy76
    Jonesy76 Member
    35
    Yes your right about the fuses they were 10 amp ones which kept blowing there fine now though and also my interior lights don't work I've tried fuses and there ok it's doing my head in now the bulbs are ok aswell ?? Any clues on how to fix
  8. The Engineer
    The Engineer Member
    356
    22
    Sent PM.
    I also need a replacement manifold for my 2004 2.0 TDi
  9. dancupra225
    667
    25
    I don't have a manifold I have egr at home two of them engineer
  10. The Engineer
    The Engineer Member
    356
    22
    PM me a price for the EGR please.
    The scan also thrown up an error for the EGR.
  11. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    Its a diesel not a petrol..
