audi a3 2L sport TDI trouble with fuel gauge
farmergeorge Mar 21, 2014
  1. farmergeorge
    farmergeorge New Member
    hi all
    ive bought a audi 2l tdi 2003 and the fuel guage said it had quarter of a tank, i went to fill up before driving home and managed to get £6.86 in diesel then it was full!! i think there is a problem because it shows on the fuel guage as having just under half a tank of diesel but clearly is a full tank
    i read the reciepts and stuff in the folder when i bought it and discovered a reciept for a sender sensor
    could it need another 1 or maybe a different fix?
    thanks
  2. Cobra88
    Cobra88 Active Member VCDS Map User Audi A4 Audi Avant Owner Group TDi
    552
    69
    First off if your 2 lt you should be on the 8p A3 section
    Anyway lift up rear seat and pull out the large black plastic plug in the floor
    Check that the mark on the fuel sender unit lines up with th mark on the tank
    If they dont the sender gets jammed on the side of the tank
    Might de different on the 8p but mine was out of line and read wrong when i fist got my 8L
    Worth checking as its free :)
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,803
    192
    Where abouts are you? Somebody local should be able to check with VCDS if the needle is working correctly or if the sender is reading correctly.
  4. farmergeorge
    Pontefract West Yorkshire - do you know anyone with one then?
