audi a3 2009 change brake pads help
deek19790 Nov 5, 2013
  1. deek19790
    deek19790 Member
    86
    hi guys.
    im gonna change my brake pads and need to ensure i have the correct tools, i know i need a piston tool but not sure if this will work for both front and back and also if this is correct tool
    Sealey VS024 brake piston wind back tool ***NEW ***SALE PRICE*** NEW*** | eBay
    or do i need the above and also
    Disc brake piston spreader seperator tool / brake calliper / pad BERGEN AT187 | eBay
    i used to just used a crow bar for my old car front but this time i think i shouldn't due to being a much better car.
    any help much appciated.
    ps. this is guide i saw http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/130954-how-change-brake-pads.html
    thanks
    d
  2. NHN
    29,332
    1,716
    1st tool is what I use, also make sure you spray some lube, say wd40 around the rubber boot of the piston, so it doesnt twist & tear as you wind piston back.
  3. deek19790
    deek19790 Member
    86
    hi mate,
    does this tool work for the front as well?
    d
  4. Dvapower
    Dvapower Member
    57
    9
    The Sealey tool is normally for rear calipers where the piston indexes as the pad wears to keep the handbrake in contention. The second one is a generic tool for returning pistons in a single or double piston regular caliper that has no handbrake scheme as those on the front.
    Dave
  5. deek19790
    deek19790 Member
    86
    Hi mate,
    Cheers for that.....
    D
  6. XFi
    XFi In need of a V8.
    491
    47
    If the bolts are the same as on my 2009 S3 then you will need a Spline tool bit but someone else may be able to confirm as I think it's either M12 or M14.
  7. crunchie
    crunchie Active Member
    880
    77
  8. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    For many years, I've been using a G Clamp for front piston and grinder's Peg spanner for the rears. Works okay.
