Audi A3 2004 water in the cylinders
chucky121 Dec 8, 2012
  1. chucky121
    chucky121 Member
    30
    Hi just purchased an Audi A3 on a 2004 plate, 2.0 tdi 140 got it really cheap but the problem is that water is leaking in to cyinder 1 and cylinder 2, there was that much water that the engine had locked up, took the glow plugs out and span it over to get the water out, heard there was problems with some of the early heads going pourus but would this happen after 77,000 miles? also is there problems with the egr cooler leaking? any advice would be great full, work in the motor trade so sort of know my way round these
  2. hughjass
    hughjass Is there somefin in my teef?
    293
    Might be just head gasket, I'm sure the veterans on here will know of other possibilities.
  3. Boon
    Boon Active Member
    441
    59
    If the engine locked up then it needs to be stripped down, it may have bent a conrod
    Really bad news if it has locked due to liquids in the cylinder
  4. chucky121
    chucky121 Member
    30
    hasnt bent a rod or done damage to pistons and valves, just want to know if it is more likely to be the head away or if its just the egr cooler leaking
  5. Boon
    Boon Active Member
    441
    59
    At the very least I'd have the head off and get it pressure tested for leaks & cracks
  6. WALTO TDI
    WALTO TDI Member
    293
    12
    What prefix letter is the head on your car? IIRC it was the early prefix heads that went porous so A B C. do a search on here and it shows you where to find these numbers.
  7. chucky121
    chucky121 Member
    30
    not sure but i would think it will be one of the early ones since its am 04 plate
  8. Lewis583
    956
    91
    Cracked/porous head. Does it always get water in cylinders 1&2?
  9. murran
    murran Well-Known Member
    1,545
    39
    yep ive had this afew times now. head cracked/porus round the inlet ports.
    when you get the head off, do check the piston height of 1 and 2 at tdc compared to 3 + 4!
  10. chucky121
    chucky121 Member
    30
    Would I be able to tell if it was the egr cooler from just disconnecting it from the egr valve then running the car?
  11. hades-
    9,482
    646
    as above head off get it checked
    how would you know it hasnt bent a rod have you had it stripped ?
  12. chucky121
    chucky121 Member
    30
    Identified the head as an early A type so it's coming off. Picked up a cheap C type head so will just get that skimmed. Apart from replacing the cambelt and water pump and head bolts is there anything else I should replace. Also are these 140 tdi's good with a remap? Thinking about doing it once its fixed. Thanks.
  13. Boon
    Boon Active Member
    441
    59
    Depends on how much your willing to spend or how long you plan to keep it
    If it was me I'd reseat the valves and get new tappets
