Audi A3 2.0TDI - Error codes...
x1nick May 19, 2012
  1. x1nick
    x1nick Member
    37
    Hi
    I have finally got the error codes off my car, luckily I haven't had to use it much recently so its just sat there.
    The two error codes I have are ( details as seen on here VAS 5051 Error Codes ):
    4C66 - P3102 Motor fur Saugrohrklappe-V157 kein Signal
    42B3 - Kühlerlüfteransteuerung 1 Kurzschluss nach Masse
    Now from googling I have found out the following
    4C66 = Engine Intake manifold-V157 is no signal wondering
    42B3 = radiator fan control a short circuit to ground, liquid cooling failure, fan spins up
    Obviously this is the handy work of some google translate, could anyone elaborate on whats wrong here? Im fairly confident in fixing broken parts on cars have changed timing belts/suspension and all sorts before, but when it comes to diagnosing the issue Im a little stuck so any help would be much appreciated
  2. NHN
    29,532
    1,768
    Intake manifold flap is probably faulty, remove it, take apart & check for broken plastic teeth inside as this is one issue, also could just be dead now aswell.
