Audi a3 2.0 tdi... Engine fell out!!
Mikemc Nov 3, 2012
  1. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Driving down the m60 just before Trafford centre, heard a bang noise as if I ran over something pulled over, to see my engine dropped on the offside side of the vehicle, bonnet won't pop so couldn't see exact damage, I'm guessing the mount has snapped/ come loose? Only bought it this Tuesday do its safe to say its going back!
  2. rOb_A
    rOb_A Active Member
    1,488
    nooooooo!!!! you must be well miffed to say the least.
    yep i'd be start round to the car dealer and give them what for :aggressive:
  3. Mikemc
    1,024
    37
    Just had it dropped off in the directors car parking spot!, gutted to be honest, loved the car!
  4. rOb_A
    rOb_A Active Member
    1,488
    dont let it put you off, i'm on my 3rd A3 so something must be right. how old is the car?
  5. Mikemc
    1,024
    37
    It's a 55 plate face lift
  6. rOb_A
    rOb_A Active Member
    1,488
    sure it will get sorted lad, keep us posted
  7. Mikemc
    1,024
    37
    I'm just gonna ask for a refund, and probably opt for the 1.9tdi 130
  8. Pops848
    Pops848 Active Member
    597
    54
    What a naff thing to happen!! It could of been worse, thankfully it stayed in and didn't do anymore damage!!
    Personally I would take it back, try for a new one and sort out some proper discount for them selling you a car that could of potentially been a death trap.
    As said above audis are good cars most the time, I'm on my 3rd, sister is on her 1st, my brother in law has had 4, all have been near on faultless apart from expected / acceptable problems.
  9. Double J
    Double J Member
    93
    15
    If you keep this one, at least you know the problem is sorted. Rather than have something similarly bad on the next one you get?
    Still a poopty thing to happen
  10. Mikemc
    1,024
    37
    I know, it's something you never expect to happen on any car never mind one renowned for build quality, I'm guessing when the mechanics of this garage mustn't of tightened the mount up after doing the cambelt change, clearly incompetent and shouldn't be allowed near be any vehicle, imagine if the lower mounts would of give way, could of potentially lost control and gone through Barton bridge!
  11. macpdm
    macpdm Member
    403
    I hear you brother and feel your pain glad your ok but some used car dealers really pee me off
  12. Lings
    Lings Active Member
    2,059
    31
    Build quality is shat
  13. hades-
    9,481
    646
    my daughters 2003 has just had a snapped mount drivers side
    snapped all 3 bolts in the engine
    its an engine out job to extract the bolts
    and the new mount is uprated tps said they sell loads.
    £300 quid lighter for the repair as i know some decent lads so mates rates.
  14. Mikemc
    1,024
    37
    Well as I've only bought it Tuesday just gone, I'm going to propose the only way I'm keeping this car is if they agree to pay the bill for an audi dealer or local vag specialist to fix anything and everything that needs fixing
  15. rOb_A
    rOb_A Active Member
    1,488
    if they dont sort it, id name and shame lad, so other can steer clear
  16. Mikemc
    1,024
    37
    They've got back to me, said it was the engine mount bolts, the one that bolt into the engine, 2 of the 3 had snapped clean Apparantly, what's the likelihood of this?
  17. hades-
    9,481
    646
    if you read post 13 its just happend to my daughters car
    its an engine out job and new mount
    it will be a uprated mount aswell the other was a bad design
  18. Mikemc
    1,024
    37
    Sorry forgot I read that, we'll I have no idea how they've gotten them out but they've said they're just waiting on new bolts?
  19. hades-
    9,481
    646
    if i was you id check they put the new mount on
    as its the mount that causes the bolts to snap
    was it on the drivers side ?
  20. rickypj
    rickypj Member
    60
    Not very likely at all, more like the mechanic forgot to tighten them after fitting the cam belt and they have snapped under the extra load place on them cus they were loose. I had the same happen but i spotted it before any bolts snapped. I saw the old bolts after they replaced them with new and they were bent like bananas.
    I would ask to see the bolts that have snapped. if they are bent they they were left loose when the mount was took off to do the cam belt.
    dont accept any ****e off them.
  21. Mikemc
    1,024
    37
    How does the mount cause the bolts to snap?
  22. hades-
    9,481
    646
    my mech and a tech at audi told me that
    the mount rubber collapses and puts preasure on the bolts engine side and the vibrations cause the bolts to snap
    the tech also told me they sell loads and thats why its a new mount
    put them togeather they look a lot diffrent.
  23. hades-
    9,481
    646
    the bolts on mine couldnt have been left loose from a previous belt change as its never had 1 and its done 60k
    and had it from new
  24. Mikemc
    1,024
    37
    Where could I source an updated mount?
  25. hades-
    9,481
    646
    mine was from VW sheffield
    but they should change it anyway
  26. Mikemc
    1,024
    37
    Ill have to ask the question, then, if they say they only put new bolts in I guess I'll have to complain and explain it needs a new mount?
  27. Mikemc
    1,024
    37
    And how much are they if it comes to me buying one?
  28. Mikemc
    1,024
    37
    A new update, they said the mount is fine otherwise they would of replaced it, I'm gonna get an indi to check it out anyway, and with regard to the turbo, they said its boosting fine etc so to them it's all fine other than the whistle noise, but again ill get that sorted by the indi I know with a new turbo under aa warranty
  29. Mikemc
    1,024
    37
  30. max69vk
    max69vk Active Member
    862
    57
    A few guys over on the Seat forums have said the Q-drive mounts are poop & fail prematurely.
