Audi A3 2.0 tdi bkd total loss of power steering PLEASE HELP 1k2423051ac
ali1211 Jan 29, 2013
  1. ali1211
    ali1211 New Member
    10
    Hello Everyone im new here, forgive me if this issue has been previously resolved if you can direct me in the right direction it will be greatly appreciated. Thanks to everyone in Advance for reading my post. I've got a audi a3 2.0tdi bkd engine 2004. I have lost all power steering and the red steering light comes up on dash along with traction control and abs lights. I've checked all fuses seem ok tried having it reset with vcds and it brings up below errors. I think it maybe the power steering assist module on the rack if anyone can confirm this please. I will require Steering rack Part no 1k2423051ac do u still have that rack? After speaking to audi dealers they confirm newer rack upgrade to this is 1k2423055k.
    Please help and tell me what you think VCDS data below
    Data version: 20121222 Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 7D VIN: WAUZZZ8P44A038072
    Mileage: 199860km/124187miles
    00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 0
    8-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Cannot be reached 1100 46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: OK 0000 -
    --Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5705 Revision: 12345678 Serial number: AUX7Z0C6FN3029
    Coding: 0000072 Shop #: WSC 06435 000 00000 VCID: 27568CF2965C0820406 No fault code found. Readiness: 0 0 1 1 1 -------------------------------------------------------------------------------
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No: 1K0 907 379 D Component: ESP FRONT MK60 0102 Coding: 0055942 Shop #: WSC 06435 000 00000 VCID: 336E68A252847480ECE 1 Fault Found: 00810 - Sensor 1/2 for Brake Pressure 005 - No or Incorrect Basic Setting /Adaptation -------------------------------------------------------------------------------
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 D HW: 8P0 820 043 D Component: KlimavollautomatH12 0150 Revision: 024730 Serial number: 8P0820043D Shop #: WSC 00000 000 00000 VCID: 2D5A7EDAB4A02270BAA No fault code found. -------------------------------------------------------------------------------
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-B.lbl Part No SW: 8P0 907 279 HW: 8P0 907 279 * Component: Bordnetz-SG 1.0 H27 0401 Revision: 00000000 Serial number: 00000000084648 Coding: 00884F00A2141000000000000000000000 Shop #: WSC 00000 000 00000 VCID: FAF00586B56EC5C8EF8 Subsystem 1 - Part No: 8P2 955 119 A Labels: 1TX-955-119.CLB Component: Wischer WWS Audi350 0170 Coding: 16711696 Shop #: WSC 00000 No fault code found. -------------------------------------------------------------------------------
    Address 15: Airbags Labels: 8P0-959-655-84.lbl Part No SW: 8P0 959 655 F HW: 8P0 959 655 F Component: Airbag 8.4ED H01 0130 Coding: 0011602 Shop #: WSC 06435 000 00000 VCID: 458A267A0C10FA3052A 1 Fault Found: 01738 - Crash Sensor for Front Airbag; Drivers Side (G283) 011 - Open Circuit - MIL ON -------------------------------------------------------------------------------
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 A HW: 1K0 953 549 A Component: Lenksäulenmodul 008 0030 Coding: 0000012 Shop #: WSC 06435 000 00000 VCID: 306467AEA3924F9891C No fault code found. -------------------------------------------------------------------------------
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 980 D HW: 8P0 920 980 D Component: KOMBIINSTR. VDO H25 0070 Revision: D04 Serial number: 2246CD04001083 Coding: 0004403 Shop #: WSC 14557 067 57207 VCID: 38745F8E4BE297D8D9C No fault code found. -------------------------------------------------------------------------------
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 B HW: 1K0 907 951 Component: Gateway H08 0070 Revision: 08 Serial number: 20001036257263 Coding: 3D0F0B4A070101 Shop #: WSC 06435 000 00000 VCID: 264881F6915611287B0
    3 Faults Found: 01309 - Power Steering Control Module (J500) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 101 Mileage: 199864 km Time Indication: 0 Date: 2013.01.24 Time: 00:49:36 00470 -
    Combination comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 101 Mileage: 199864 km Time Indication: 0 Date: 2013.01.24 Time: 00:49:36 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 101 Mileage: 199864 km Time Indication: 0 Date: 2013.01.24 Time: 00:49:41 -------------------------------------------------------------------------------
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 8P0 920 980 D HW: 8P0 920 980 D Component: KOMBIINSTR. VDO H25 0070 Revision: D04 Serial number: AUX7Z0C6FN3029 Shop #: WSC 14557 067 57207 VCID: 38745F8E4BE297D8D9C
  2. Best84
    Best84 Member
    137
    Oh gosh, my eyes!! wall of text.
    My mate had this issue on his Tdi, he needed the rack and servo for the steering. The rack he got from GSF with part ex for his old one and the servo he had to get from Audi. Needs coding aswell I believe. I think in all he paid around £750 :(
    He was told these are a common issue...
  3. ali1211
    ali1211 New Member
    10
    The servo? Is that for the abs? Or the electric module on rack?
  4. Best84
    Best84 Member
    137
    Module on the rack. I dont understand why they didn't just use a pump/fluid. :(
  5. ali1211
    ali1211 New Member
    10
    Thank you for the quick response best,
    I had a gut feeling its gona need a new rack
    Rang audi in bradford and the quoted me 909 pound thats extortion
    Ive tried quite a few local breakers and they have racks rangining from 70 to 300
    But non of them codes fully match the last two letters are always different
    Looklike i nedd to keep looking for second hand one i cant afford to oay almost a grand for rack
    Do u know of any decent audi breakers?
    Thank you once again
  6. Best84
    Best84 Member
    137
    Nope sorry mate. My mate had that exact same issue. You gotta remember that the second hand rack could only last a few weeks too. At least new you will have a two year cushion...if you plan on keeping the car that long :)
    This whole ordeal has made him consider switching to a Civic 2.2
  7. ali1211
    ali1211 New Member
    10
    Your quite right its a risky job with a second hand
    Ive heard people can recondition rcks and module may thats a better option
    Read a post earlier stating its about 350 to recondition and will come with a guarantee
    Just need to be sure its the cause so im not splashing money for something thats ok
  8. Best84
    Best84 Member
    137
    I'm sure GSF did his rack for around £150 with his rack as part ex. Its the module that's expensive and you can only get them from Audi.
    If you find a place that can recondition the whole lot please let me know, be handy to know if the worst does happen :)
  9. ali1211
    ali1211 New Member
    10
    There is somebody who does them in rochester charges 35 to check rack and if faulty 300 to recondition rack and module im going to try find them and will post it if i do.
    Many thanks once again
  10. ali1211
    ali1211 New Member
    10
    Jus been advised to check power is getting to j500 the rack module
    This will establish if the rack is getting power and correct me if im wrong
    If the rack module is getting power and not responding it s busted and needs replacing
    If ut is not getting any power then there could be a beeak in the circuit
    And will need to follow back to see where the current is being lost.
    Thanks nhn your a star will do this and post back results
  11. ali1211
    ali1211 New Member
    10
    Update
    I can cinfirm the code dies not nedd to match
    I have just obtained a rack n module from a 2011 audi a3 part num 1k2423051cj
    This psrt code is different to mine however is the new updated rack
    The rack took two hours to remove and two hours to fit
    Quite a easy job for a experienced mechanic
    Power sterring works and fully operational
    If upgrading rack to newer you will need short wiring on rack.
  12. Neb86
    Neb86 New Member
    hi hoping you guys can help me, I have recently purchased a 2.0 tdi bkd a3 2004 model, had it 2 weeks and its now lost all steering :(
    I have got the steering wheel symbol on dash, all fuses are intact and its getting power to the module.
    what do I need to fix this issue, according to tps its £964 for everything!! I just cant afford that.
    according to them my car has the 1K2423055KX STEERING RACK
    any help would be appreciated!!
  13. Theo12848
    Theo12848 New Member
    Where is j500
    Sent from my SM-G901F using Tapatalk
  14. Keram
    Keram Active Member
    236
    39
    On the subframe.
