Audi a3 2.0 tdi(2004)- screeching/chirping noise from engine?
Weechris90 Jun 2, 2012
  1. Weechris90
    Weechris90 Member
    98
    Started my car this morning to find unusual noises from the engine.. It was a mixture of screeching/chirping noises? Also does it occassionally when driving?
    Anyone know what this could be?
  2. Royceyy
    Royceyy New Member
    I had something similar, turned out the be a leak from the exhaust manifold gasket, it caused it to screech under heavy load, I also had a split boost pipe lol :/ - but lots of things can cause screeches e.g belts etc.
  3. Graham89
    Graham89 Derv Perv
    310
    Sounds like a squeaky power steering pump to me. You could try spraying some WD40 on the auxiliary belt. If it stops squeeking you'll know either the tensioner, belt or pump is at fault.
  4. The Engineer
    The Engineer Member
    356
    22
  5. Weechris90
    Weechris90 Member
    98
    Ok guys, thanks. Will try some wd-40 first and monitor it! :)
  6. Weechris90
    Weechris90 Member
    98
    Ok the noise is getting worse and seems to be coming from the cambelt? Tensioner maybe?
  7. Lewis90
    Lewis90 Member
    37
    id be interested because my car does this as well
  8. The Engineer
    The Engineer Member
    356
    22
    Mine did this for around a month, I left it and left it then it got worse.
    Ended up replacing the belt, tensioner and alternator as somehow the alternator pulley bearings perished resulting in it falling off.
    Get it looked at ASAP as you may save yourself money.​
  9. Lewis90
    Lewis90 Member
    37
    mine only does it when in rotation, not when revved up at stand still? reakon this could be the belts?
  10. Cromarty32
    Cromarty32 New Member
    Could be the pulley on the alternator - the origibals usually seize up. You can buy replacements at DI parts for about $60 - MUCH cheaper than Audi!!
    Let us know what it turns out to be.
    Paul
  11. Weechris90
    Weechris90 Member
    98
    Hi guys, car went in yesterday and its the fan belt tensioner! New parts ordered and getting fitted today :)
  12. Weechris90
    Weechris90 Member
    98
  13. The Engineer
    The Engineer Member
    356
    22
    Sorry to hear that bud, a good friend of mine got me a 2010 alternator for a great price.
    Try breakers for it as it will save you some pennies, make sure you get it done soon as you don't want to risk the pulley falling off like mine did :(
  14. Graham89
    Graham89 Derv Perv
    310
    You'll only need an alternator pulley. You can replace these if you take it to an auto electrician. I got mine replaced on my work van an it cost me £30 much better than the price of a new alternator.
    I wouldn't know how much Audi pulleys are though.
  15. Weechris90
    Weechris90 Member
    98
    The guy that does the work on my car said there was slight play in the alternator but it was still turning ok, still just need a pulley??
