Audi A3 2.0 TDI 140hp boost hoses now ready to order
Discussion in 'Sales' started by kris@forge, Nov 1, 2010.
  1. kris@forge
    kris@forge Site Sponsor
    Site Sponsor
    Aug 19, 2010
    42
    A set of three Silicone Boost Hoses for the VAG 140 hp 2 litre Diesel as found in the
    * VW Mk5 Golf 140 TDi
    * SEAT Leon MK2 140 TDi
    * Audi A3 140 TDi
    These hoses are Flourolined to protect against oils and discolouration. All hoses are complete with alloy couplers. Please note that the rubber seal needs to be transfered and re-used from the original fitment couplers to the new alloy couplers.
    Available in Blue,Black or Red
    Forge Motorsport | Alloy Fabrication
    Remember to use your 10% discount code (as10)
  2. Advert Guest Advertisement
  3. heeman10
    heeman10 Audi driver since Dec 08
    Dec 19, 2008
    375
    These look brilliant, but do you guys produce anything that overcomes the poor design of the original boost pipe seals?
  4. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    yes we have beter alloy couplers with a beter design so that clip is very secure
  5. asasprey
    asasprey Member
    Mar 14, 2011
    125
    Do you guys supply the seals? and if so are they just cruddy standard audi ones??
  6. asasprey
    asasprey Member
    Mar 14, 2011
    125
    ahh, just answered the question myself!!
  7. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    Hi no the seals dont come with our kit , you have to use your old ones
  8. Gti Jazz Blue
    Gti Jazz Blue Active Member
    Feb 26, 2007
    1,655
    Just ordered a set to try on my PD140 as we will have it up on a ramp soon to give the Turbo a clean as I'm getting over boost faults. Have a complete set of new seals to use with them too.
    Paul
  9. Blueie
    Blueie He who dears' wins!!
    Aug 26, 2009
    347
    Could i ask how much you paid for the seals?
  10. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    Enjoy Gti Jazz blue
  11. Gti Jazz Blue
    Feb 26, 2007
    1,655
    They have arrived as promised - great service thanks. Look fantastic in the flesh.
    I'll have to dig out the receipt for the seals which is at home and post tomorrow.
    Paul
  12. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    That would be great buddy
    Thanks Kris
  13. Lings
    Lings Active Member
    Jun 6, 2010
    2,069
    31
    These look good
  14. Gti Jazz Blue
    Feb 26, 2007
    1,655
    They look very good in the flesh - I still haven't managed to post the seal prices, I'll see if I remember over the weekend.
    Going on the car next Tuesday when we try the Innotec on my Turbo and have some ramp time.
    Paul
  15. Gti Jazz Blue
    Feb 26, 2007
    1,655
    Dug out the paperwork and the replacement gaskets came to £22.78 plus the VAT. If you get them fro your local TPS counter you will probably get some discount on that price some on mine have 10% discount and some 8%.
    I ordered some other stuff that I required so can't post just the total on the bill. I also bought some of the replacement clips and they come in at about £1.05 ea plus VAT less any discount applied.
    Hope that helps.
    Paul
  16. Blueie
    Aug 26, 2009
    347
    Ideal thanks!
  17. Gti Jazz Blue
    Feb 26, 2007
    1,655
    OK we have fitted my set, my thoughts :-
    The alloy connectors are miles better than the stock oem hoses, they really need a positive push and then engage tightly into the connection.
    Ideally you need the car up on a lift to replace them, at a push you could do it on a set of ramps or axle stands, but it would be a lot easier up in the air above you. The one that connects to the EGR / IMF is a pig to do due to the hoses round it, there is limited access (small hands may help)
    Also to clarify (as I did see it in the description, but I may have missed it) it is a set of three that replace the flexible hose at each end of the Inter-cooler, and the one at the front behind the fans that connects the pipe to the EGR/IMF.
    Paul.
    #16 Gti Jazz Blue, May 5, 2011
  18. Blueie
    Aug 26, 2009
    347
    Noticed a difference?
  19. NHN
    NHN Retrofitter - Audi - VW - Skoda - Seat
    Site Sponsor VCDS Map User
    Jan 14, 2008
    29,125
    1,644
    Yeah I also would like to know if its euphoria or real difference, as I have stock pipes oin hybrid with 230 atm & I have no issues.
    I appreciate forge kit is good & my dealings on my S3 were very good in the past & helpful, but has to make a difference to be worth purchasing.
  20. Gti Jazz Blue
    Feb 26, 2007
    1,655
    Can't report back yet as the OEM connector at the Turbo has popped off, didn't notice it until I could hear air escaping on the way home. We also just cleaned the Turbo and we had noticed before a sound of boost leaks, I guess sorting the VVT on the Turbo resulted in a slug of boost when I backed it over the two post lift and moved the pipe even more.
    I can just get a finger to it but not clip it up again from above, so will need to get under the car at the weekend to fix it. Driving gently at the moment with a lot of air hiss.
    Love to get my hands on who ever design these locations so that you can only get to them from below. Also what is wrong with good old fashion hose clamps for these unions, in place of these stupid ears and clips.
    I would say that the forge ones are very unlikely to pop out as the billet ends are of a much more robust design.
    Wish they did one to replace the short right angle hose at the turbo outlet.
    Paul
  21. Blueie
    Aug 26, 2009
    347
    So the Forge ones only replace the ones at the bottom where the intercooler is?
    Do you think because the forge ones hold good preaure put a weakness/more presure on the OEM ones to the turbo?
  22. Advert Guest Advertisement
    to hide this advert.
  23. Gti Jazz Blue
    Feb 26, 2007
    1,655
    They are the hoses each side of the inter-cooler and the one from the solid pipe behind the fans to the EGR / IMF.
    No I had a boost leak anyway we could hear it as well as sticky vanes on the turbo, as we were having it up on a ramp to do the turbo I decided to purchase the forge ones to replace the stock ones as you can see where they have been leaking at the inter-cooler.
    I don't think the forge ones caused the stock turbo one to pop off - I think it was already slightly out, but sorting the turbo has popped it more.
    Paul
  24. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    we will be doing the turbo hose soon , but this will only come in the nomex (ocre colour) as it will need to take high temperatures.
  25. Gti Jazz Blue
    Feb 26, 2007
    1,655
    That isn't really likely to cause an issue as you can only see that one from below on a ramp with the undertray off.
    Can't wait for news on this one Kris.
    Have you worked out the probably cost of it yet ?
    Paul.
  26. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    We havent worked out the cost yet but ill keep you all updated
    Kris
  27. garag
    garag New Member
    Nov 25, 2010
    Hi !! suscribed here...I'm interested to get all boost hoses to fit MKV 2.0tdi bkd engine, would you have any pics or comprehensive instructions to see how the hoses look? thanks
  28. b9rgo1234
    b9rgo1234 New Member
    Feb 9, 2011
    Do you have any plans to do coolant hoses got the 2.0tdi engines?
  29. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    If we get 10 people who 100% want these then we will make them
    Please let me know
    Thanks Kris
  30. NHN
    Jan 14, 2008
    29,125
    1,644
    Urrm I maybe interested in this Kris.
    Whats delivery timescale for the IC 3 pipes to UK & to Italy?
  31. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    We ship via UPS standerd which will take up to 5 working days
    We can send via express this will take 2 working days but costs 50% more
  32. garag
    garag New Member
    Nov 25, 2010
    If i go with S3 IC and chopped stock hoses ... if i order these ones I'll have to chop them also, is it difficult?
    #30 garag, Jun 22, 2011
  33. Forge
    Forge Member
    Jun 6, 2003
    204
    Hi
    I am unsure whether these will fit as we have not ever fitted a S3 intercooler to a TDI
  34. Gti Jazz Blue
    Feb 26, 2007
    1,655
    Any news on the Turbo one yet ?
  35. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    Not as yet im stil waiting on tooling.
  36. Gti Jazz Blue
    Feb 26, 2007
    1,655
    Any update on this one yet ?
  37. kris@forge
    Site Sponsor
    Aug 19, 2010
    42
    We trial fitted a hose to the 140 tdi and it was not a good fit so we are back in the stage of new tooling
