Audi A3 2.0 FSI 2004 - Management light and MPH 1???
Eazyd May 12, 2013
  1. Eazyd
    Eazyd New Member
    17
    Hi All, Here is my issue - My younger brother has just purchased an Audi A3 2.0 Fsi (Without me!) He took it for a test drive and all seemed fine, FSH, one owner etc. He has just drove it back to Birmingham from Leicester and after about 20 miles on the Motorway the engine management light came on and a light stating MPH 1? He says it seem to drive fine but obviously this is of concern! Any suggestions Please. :(
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    26,980
    9,964
    ​Have you run a vcds scan on the car?
  3. Eazyd
    Eazyd New Member
    17
    No not as yet! He has literally purchased it about 1hr half ago.
  4. Sandra
    26,980
    9,964
    try get a vcds scan done asap to see if it throws up any faults:)
  5. Eazyd
    Eazyd New Member
    17
    Will do! Just wanted to see if it was a common fault!
  6. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Could you post a picture of the MPH1 thing?
  7. shariain
    shariain Well-Known Member
    1,182
    190
    The mph1 could be the speed alarm that you can set by pulling or pushing the button on the instrument cluster when you are moving at a speed. Basically if you drive at 30mph and pull or push the button on the cluster it sets it and then when you go over 30mph it beeps to tell you your going faster than you wanted. I think this resets its self once the engine has been turned off.
  8. a6_chris
    1,883
    160
    Ah yes, correct.
    Speed warning, doh! ;)
    The EML will need investigation though ;)
  9. Eazyd
    Eazyd New Member
    17
    Cheers guys!
  10. Eazyd
    Eazyd New Member
    17
    Hi Guys, Used my mates cheap vagcom codes came up: 18711, 16688, 16684... Any suggestions?
  11. Sandra
    26,980
    9,964
