Audi a3 170tdi quattro
whiteek4 Sep 25, 2012
  1. whiteek4
    whiteek4 Member
    30
    Hi, am after some help. I have a a3 tdi 170 quattro, 2007 plate. Recently it has been struggling to start. You would think the battery flat. When trying to start it turns over really slow which would point to a flat battery but once it turns over about 5 time it turns over normal speed and starts. I have had the battery checked and seems ok. Anyone have any ideas would be great!
  2. mjr901
    mjr901 Guest
    starter motor maybe or glow plugs.
  3. whiteek4
    whiteek4 Member
    30
    Would glow plugs make it turn over slow?
  4. mjr901
    mjr901 Guest
    Not really no.. I'd try replacing starter motor first to be honest.
  5. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Always depress the clutch when starting.
    I'd say have starter motor checked and then glow plugs.
  6. audicruiser
    audicruiser Audi Heaven
    1,865
    Replace the battery... The battery may be testing ok but I bet it's on it's way out! Especially at 5 years old.
  7. SWILKO
    SWILKO Member
    105
    Defo get a new battery. The one to get is a Varta E44, it's been discussed to death on ASN. I bought one recently, £75 from Amazon.
    S
  8. c_w
    c_w Well-Known Member
    1,169
    91
    It's temperature-related and all PD 170Tdis do it IMO when the ambient temps get to around 10degrees. The starter works fine but the engine takes more turns to start or starts and fails to catch. Mine has just started doing it again since earlier this year now the temps have dropped this past week. It's odd because it not exactly near freezing and the glow plugs don't really need much action unless it gets to around that temp.
  9. whiteek4
    whiteek4 Member
    30
    Thanks for the help guys. A have since fitted a new battery and this has seems to of solved he problem! :) thanks
  10. SWILKO
    SWILKO Member
    105
    Glad you got it sorted. Seen a huge difference in mine after fitting the new battery....
  11. audicruiser
    1,865
    Nice one, glad you've sorted it!
