Audi A3 170 BHP New Remap and DPF delete and car is hesitating in 3rd and 4th
theo289 May 9, 2013
  1. theo289
    theo289 Member
    293
    Hi All, To provide an update, since having all of the new parts put onto the car, i took the vehicle for its stage 1 remap today and it is STILL hesitating :(
  2. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Well you just found the problem.. The car was fine after it came back from Audi. You said it was ready for stage 1 and since doing so, its back to hesitating..
    It is the map dude, you even said it yourself, just without realising it and working it out.
    Jonse likes this.
  3. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,258
    588
    It's a long way but you are welcome to have a free trial of my software/map.
    Rick
  4. theo289
    theo289 Member
    293
    Very nice of you - may have to have a chat with the mrs and see if i could persuade her for a day out in Liverpool :)
  5. theo289
    theo289 Member
    293
    Exactly - i tell the tuner this and i get.... oh its your inlet manifold....then its 'its your pistons' and then its something else each time! £400 for a headache...would have preferred to have gone on public tv and been humiliated by jimmy saville!
    Artimus likes this.
  6. theo289
    theo289 Member
    293
    Quick question - your maps...are they elite maps? because this is supposedly where my map came from
  7. theo289
    theo289 Member
    293
    What was needed to be tuned on your maps? was it fuel?
    Mine is a strange juddering around 2.5k-3k if you absolutely hoof the **** out of the car in 3rd, 4th and a little in 5th.
  8. chris.vincent3
    604
    34
    what gets me is you went back a second time? I'd be asking for my money back, mention trading standards and go somewhere else.
  9. theo289
    theo289 Member
    293
    Slight issue as i got a load of my mates to get their car remapped at the same time and in order to get discount, it all had to be cash
  10. chris.vincent3
    604
    34
    Your friends cars' maps are all good I assume?
  11. theo289
    theo289 Member
    293
    I am probably the must unluckiest person in the world - yes...their cars are fine
  12. c_w
    c_w Well-Known Member
    1,163
    87
    Cash is still money though? Anyone that sells something cheaper "for cash" is hiding it from the books of course.
  13. theo289
    theo289 Member
    293
    Yeap - just didnt realiase that i would have all of these issues. I had been recommended by him from quite a large, well reputable company in Bristol who do lots of VAG work.
  14. c_w
    1,163
    87
    Can they not just take it off and give a refund? It shouldn't matter if it was a group buy, if it gives faults then that is good reason to remove it and refund your money.
  15. theo289
    theo289 Member
    293
    have now done an awful lot of reading on this and it seems like it could now be either the glow plugs, injectors (supposedly have previously been changed), oil in the fuel, MAF or tandem pump fault
  16. max69vk
    max69vk Active Member
    862
    57
    It's your map, end of. Get it removed, get your money back & go to a tuner with a good reputation for working on these cars (there's plenty on the forum).
    Glow plugs only help when starting the car and do nothing above 5 degrees temp, injectors would cause faults thoughout the rev range, oil in the fuel blocks the fuel filter over time but as it burns like fuel it wouldn't cause a misfire only at a certain RPM, if the MAF was gone you'd get get sweet FA power over a certain RPM in any gear.
    Artimus likes this.
  17. Artimus
    Artimus Shortback
    2,016
    485
    :icon_thumright:
    corrected this for you
    ...or keep the map & accept the problems that obviously go with it.
    Where's the "head in sand" smiley when you need it?
  18. theo289
    theo289 Member
    293
    Hi All,
    Its been quite a long winded exercise but i have now found out what was wrong with the car - the map!
    Basically the tuner had the car over boosting which was causing the car to gain boost, loose it, gain it again and again loose it.
    Best bit after all....the guy who did the map (avon tuning - bristol) says the map is still fine! chopsy!
    Thanks everyone for your help
    Artimus likes this.
