Audi A3 170 BHP New Remap and DPF delete and car is hesitating in 3rd and 4th
theo289 May 9, 2013
  1. theo289
    theo289 Member
    293
    Hi All,
    Literally just got my car remapped with a Stage 1 and DPF delete and theres a large issue with the remap where when i boot it in full load in third and fourth that the car just judders around 2000x-revs + - just seems as if the car is either hesitating or loosing power here and there.
    The only thing on the car which has been changed is the air filter - have a CAI Carbonio Inlet.
    Any help would be very much appriciated
  2. Tempy
    Tempy Member
    157
    15
    What have the tuners said? Have you spoken to them yet? It would be the first thing I did if I was having issues. They should be putting any issues right if there are problems with the map.
  3. theo289
    theo289 Member
    293
    That was the first thing that i did :yes: and he has said that the issue is with my air intake and that i needed to swap it over with my original one
  4. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    Cant see it being that unless the intake is blocked completely.
    After having mapped numerous diesels and deleting the DPF I have felt this hesitation on afew diesels. Turned out to be a choked EGR valve so ended up doing an EGR delete (software only) so the customer could enjoy the new power and delete the EGR at a later date.
  5. theo289
    theo289 Member
    293
    Sounds great advise! Am i able to drop you a quick call tomorrow?
  6. Tempy
    Tempy Member
    157
    15
    Ah cool. Sorry just wanted to check as you didn't mention it in your first post.
  7. TDI140
    TDI140 Well-Known Member
    1,632
    175
    standard air box is good or go for an APR intake from a 2.0tfsi that does a good job, also check for boost leaks in all turbo to intercooler hoses
  8. theo289
    theo289 Member
    293
    Was rather hoping it wasn't the air filter as the carbonio cost me just over £250. I'm fitting my standard one back today to see what that is.
    The tuners have said that if it is the air box, they would happily take the car back to tweak it. But they were just unsure of what the issue exactly was.
    Will keep you all updated
  9. TDI140
    1,632
    175
    What carbonio was it ? If its a boxed carbonio then it wouldnt be air filter but if its open cone then most likely is
  10. theo289
    theo289 Member
    293
    its a boxed carbon fibre one - worked perfectly prior to the remap. Been out in the car today and in 6th it's even hesitating
  11. max69vk
    max69vk Active Member
    862
    57
    Sounds like a fuelling issue to me.
    Check the fuel filter as the extra airflow created from using the Carbonio will mean the engine also requires extra fuel to maintain ratios. If the fuel filter is clogged it wont deliver enough flow at the required revs - 2krpm in 4th,5th & 6th will be the maximum torque 'area' in the rev range, so the stuttering in this range isnt really a coincidence.
    Personally I'd ditch the Carbonio, the standard airbox is ugly as sin but it flows more than enough, doesnt let 99% of the crud through that aftermarket filter will (which will then nicely sand your engine internals), + it's designed so you wont hydrolock your engine if you scoop up a load of water in the front end.
  12. TDI140
    1,632
    175
    Deffo not filter put that back on, it sounds like fuel filter as stated above should have had service before getting remapped mate
  13. theo289
    theo289 Member
    293
    Am going to buy the new fuel filter and will swap it all over today - will let you all know
  14. theo289
    theo289 Member
    293
    stupidly spoke to Bristol Audi today and asked them why this wasn't changed last time my car went in for its service and they said to me that they weren't sure exactly why it wasn't change.....
  15. c_w
    c_w Well-Known Member
    1,168
    90
    I'd be surprised if the air filter is the fault. If it drove fine before it should drive fine after otherwise it wasn't mapped "properly" surely?
  16. theo289
    theo289 Member
    293
    Exactly what i thought! have my new fuel filter so just waiting on fitting it and see what it does :)
  17. TDI140
    1,632
    175
    Fuel filter doubt fuel pressure regulator is faulty, compare new and old filter if the old one looks proper bad then the new one should resolve it but if it is the map then i would dyno it and look at the torque curve and see whats wrong and take it back and get your money back for the remap
  18. theo289
    theo289 Member
    293
    New fuel filter is now fitted - just letting the engine tick over then will take it for a spin :)
    Fingers crossed
  19. theo289
    theo289 Member
    293
    Oil filter pre-change
  20. TDI140
    1,632
    175
    Good luck pal hope it was the filter
  21. theo289
    theo289 Member
    293
    Thanks! Just wanting to get out of work asap and get on the link roads :)
  22. max69vk
    862
    57
    The air filter change won't be the cause of your issue, it will highlighted anything that was previously wrong though, hence me suggesting the fuel filter change... Looking at that fuel filter I'd say that it definitely won't have been helping things even if it isn't the ultimate issue causing your stuttering.
  23. theo289
    theo289 Member
    293
    fuel filter changed and exactly the same issue. i fed this back to my tuner and he said that it could possibly be the injectors as there was an injectror recall done on my vehicle a few years back - this concluded that it has already been done.
    Started to get a little stummped here
  24. max69vk
    862
    57
    I'd this has only started since the air filter and remap try changing back to the standard air box, if the problem persists then in theory it can only be the remap. Even if the injectors need adjusting the tuner should have really made sure that this wouldn't have been a problem before slinging a map on the car.
  25. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,282
    617
    Does it do it on standard software? The injectors need to be health checked and clearances set. If this is ok, then get the tuner to gradually increase the fuelling and see at what point the issue starts happening, logging as you go.
    I know it's in my interest to say this but this is why you should go to a specialist that knows the car, and knows how to map it. No way would I let a car go in this state.
    Rick
    RedDejavu and Brodster like this.
  26. theo289
    theo289 Member
    293
    Hi All,
    Since changing the fuel filter, having an EGR removal as well as putting my stock OEM air filter, the issue is still persistent :(
  27. max69vk
    862
    57
    Out of curiosity, who mapped the car?
  28. theo289
    theo289 Member
    293
    Chap in Bristol called 'Avon Tuning'
  29. phil76
    phil76 Active Member
    572
    40
    Are you sure its not clutch slip with having a remap and a dpf removal , a whole lot of extra torque there
  30. theo289
    theo289 Member
    293
    Defo isn't clutch slip - just looses power and the whole car judders. Seen a mates S3 with clutch slip and when you hoofed that, it just revd a lot higher. This feels and looks completely different.
  31. phil76
    572
    40
    Egr stuck open just venting boost straight out of the exhuast ?
  32. theo289
    theo289 Member
    293
    Wouldn't the EGR delete get around this?
  33. Jonse
    Jonse Active Member
    448
    49
    Yeah its not clutch slip(im the mate with the s3). It feels like someone is applying the brake really hard on and off.
  34. theo289
    theo289 Member
    293
    Have now spoken to my Tuner again and he has said that the EGR delete is still doing nothing. He did however ask a few questions in regards to the Cambelt on the vehicle and if it had been changed or not....but seeing as the car only has just over 40K on, im guessing it wouldn't have needed any changes?
  35. theo289
    theo289 Member
    293
    Hi All,
    After now three times of the car going back and forth to the garage, the fault has been found! - a cracked manifold!
    Am now having to go back to Audi to see if i can claim a new one under my warranty - will keep you all updated
  36. theo289
    theo289 Member
    293
    Hi All,
    To provide an update. The car has been in with Audi for quite some time, new inlet manifold and turbo and it is still having exactly the same issue.
    Have got the car on Stage 0 + DPF off and the car is hesitating here and there - Audi have confirmed this issue.
    Anybody got any ideas?
    Thanks!
  37. A3 Tom
    A3 Tom New Member
    I had exactly the same problem after a remap and mine went to audi and everything and no could work it out, it turned out to be the map.
    Take it back to him and get the power turned down.
  38. A3 Tom
    A3 Tom New Member
    My mapper had to buy the original file because mine was corrupt then he tuned that and put it on car and its all good now!
  39. theo289
    theo289 Member
    293
    am now collecting the car later tonight as no more work can be done supposedly .... will keep you all posted with an update
  40. theo289
    theo289 Member
    293
    after weeks of the car being in at Audi, the issue is now fixed!
    what was done:
    - new EGR gasket
    - new inlet manifold
    - new turbo
    - new fuel filter
    - all boost pipes cleaned
    Car handles like a dream now and is defo ready for a stage 1!
