audi a3 1.8t quattro sport 180 ARY 2002
spencewatts Jul 19, 2013
  1. spencewatts
    spencewatts New Member
    10
    HI GUYS.my car keeps throwing up the fault code 17939, which is either the camshaft sensor or adjustment valve.it does seems to idle a bit more rough than it used to.any ideas, as I dont want to replace the wrong part.a few times the eml light has come on.i dont know if thats to do with that or not.i have no other fault codes apart from this one.regards spence.
  2. <tuffty/>
    20,571
    3,586
    17939/P1531/005425 - Ross-Tech Wiki
    17939/P1531/005425 - Camshaft Timing Adjustment: Open Circuit
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Possible Causes
    Fuse(s) faulty
    Wiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205) faulty
    Possible Solutions
    Check Fuse(s)
    Check Wiring and/or Connector(s) from/to Camshaft Adjustment Valve (N205)
    Check/Replace Camshaft Adjustment Valve (N205)
    Check the VVT is plugged in
  3. spencewatts
    10
    Thanks for pic.i take it connector on the right of the engine is what I need to check ? Thanks spence
  4. <tuffty/>
    20,571
    3,586
    Yep...
    If its connected then check the wiring... open circuit suggests a break in connection so either not plugged in or a break in the wire
