AUDI A3 1.8T EXHAUST
AGU-TURBO May 22, 2010
  1. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    HI ALL JUST WONDERING IF YOU COULD GIVE ME SOME ADVICE ON A EXHAUST. IM JUST WONDERING IF THE GOLF GTI 1.8T OR SEAT LEON CUPRA EXHAUST SYSYTEMS ARE THE SAME. REASON IM ASKING IS BECAUSE I HAVE SEEN NUMEROUS PEOPLE ADVERTISING EXHAUSTS SAYING THEY FIT ALL 3.
    THANKS
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,231
    2,052
  3. DenCar
    DenCar Member
    404
    Maybe you should contact the Vendor and ask for clarification.
  4. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    GOlf exhausts fit...but you need to trim the bumper and a bit of sheet metal behind it.. No big deal really.
  5. HTC
    HTC Active Member
    3,428
    9
    Yup, Golf exhausts fit. Here are some pics of where you have to trim
    The plastic on the rear lower bumper has to be trimmed to. Very easy to do.
  6. Imteyaz
    Imteyaz 6th Gear
    535
    I wonder if it's in the right position for a rear S3 bumber? Looks very close, IIRC, when I fitted my S3 rear bumper to my A3, the exhaust tailpipes had to be moved over about 4" to the right, if it does fit in exactly the same position, then it'll give me more options on rear exhausts available 'off the shelf' as the only option I currently have are custom made backbox [runs off to check exhaust alignment]...
    [Back again!]
    Yup, my exhaust tailpipes line up about an inch away from the spare wheel well and the pic above looks to be very similar... even the height of the tailpipes look as though they will be just perfect. Big thanks to HTC for the images posted!
  7. AGU-TURBO
    616
  8. Chlippo
    Chlippo Member
    679
    15
    i dont think that works for an S3...
    so how did you get the back box from an S3 fit your A3....im kind of lost here
  9. Imteyaz
    Imteyaz 6th Gear
    535
    I only fitted an S3 bumper but used the exhisting A3 exhaust, had new tailpipe trims welded on after they extended the pipework to shift over 4" to the right as per S3.
  10. Broken Byzan
    13,237
    465
    I stuck an S3 rear box on the A3 TQS and it fitted into the S3 bumper cut out perfectly. The A3 box tail pipes lined up fine, but were down turned.
    Not sure if the 2wd Golf exhausts are the same fitment, but no reason to assume not
    edit, i had to cut the same section out as the pics, so i recon its a go er !!!
