audi a3 1.6 2000 speedo not working
ity768 Oct 30, 2007
  1. ity768
    ity768 New Member
    10
    PLEASE PLEASE HELP!!
    hi, my speedometer and oddometer have stopped working i thought it would be something simple like a fuse or something but it isnt please can anybody help id be very thankful if you could..everything else on the dash is working fine,,
    thank you very much for looking
  2. rodenal
    rodenal Active Member
    1,992
    do you have access to vag com?
    maybe get somebody to scan for codes for you, should be able to get an idea of what is wrong.
  3. ity768
    ity768 New Member
    10
    i did, no faults came up they said it might be the whole instrument panel that may need replaceing. i'l jst have to do that
  4. marms
    marms Member
    833
    Gulp.... sounds expensive.
    Can you get someone to go in the car with you and monitor the vehicle speed via VAG-COM at least you will know is its the actual clocks or the speed sensor (which I belive is on the wheel on an 8L but I may be wrong).
  5. patrick swayze
    patrick swayze Member
    81
    apparantly its a relativly common failure. mine also doesn't work, not only the speedometer and tachometer, but my fuel gauge and some other things also do not work.
    being in the us, it nearly impossible for me to find a replacement part, but i have found a local place that can repair it "supposedly".
