Hi,
I, well the extremely talented Paul from this forum, are having a few issues with coding the door mirrors to fold on locking and unfold on engine start up. The first set of instructions - see below - activated the folding mirrors, but the window switches on the drivers door went haywire. The drivers side window switch operated the passenger window and the switch for the passenger window on the drivers side did nothing. I couldn't open the drivers window with either switch. Also the door mirror adjustment was the same, so when the drivers side mirror switch was set to adjust the drivers mirror, the passenger mirror moved, yet moving it to the passenger side, nothing happened.
Go to control unit "42-Door Elect, Driver">> Coding - 07 >> Byte 4
Change the original coding 00010000 to 01010000
With the coding put back to the original setting we then tried anothe set of codes below, but this did nothing.
Folding Mirror when Doors Lock]
Select STG 42 (door Electrical driver)
STG Long Coding -> Function 07
Byte 4
Bit 6 Activate
STG 52 (door Electrical front passenger)
Byte 4
Bit 6 Activate
My car is a 2016 A1 Black Edition with the Design pack, so has folding door mirrors.
Thanks in advance.
The scan after the first attempt is below.
VCDS Version: Release 15.7.4 Running on Windows Vista x86
Data version: 20160216
www.Ross-Tech.com
Wednesday,13,July,2016,20:08:27:37649
Chassis Type: 8X (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 25 42 44 46 52 55 5F
VIN ***********************Mileage: 6400km-3976miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CZEA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 AQ HW: 04E 907 309 AB
Component: R4 1.4l TFS H23 2408
Revision: R6H23---
Coding: 00250032242401080000
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_ECM14TFS01104E906027AQ 001004
ROD: EV_ECM14TFS011_AU21.rod
VCID: 73EE4B04DA2639A673-8026
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 065 J HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6501
Revision: 00043014 Serial number: CU501511306411
Coding: 0000020
Shop #: WSC 00046 000 00000
VCID: 3668B21041D46C8E94-8062
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6C0 907 379 L HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08501564151206
Coding: 33DF488B8E2A33C11117106F0057CC1271CC8808000AE3090F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 3874BC2883C09AFE86-806C
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8XA 820 043 HW: 8XA 820 043
Component: Klima 1 Zone H01 0010
Serial number: 00000000377075
Coding: 6420080880
ASAM Dataset: EV_AirCondiFrontAU210 007002
ROD: EV_AirCondiFrontAU210.rod
VCID: 02001EC0959C002E68-8056
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 AB HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0817
Revision: AC113817
Coding: 08000A2FB805F100201841E82104894C53FF620A21EF5922E408878700C5
Shop #: WSC 00046 123 12345
VCID: 7CFC6038FF7876DE22-8028
Subsystem 1 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Coding: 02005D
Subsystem 2 - Part No: 8X0 951 177 A
Component: Sensor, DWA 0 005 0002
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels: 8X0-919-475.clb
Part No SW: 8X0 919 475 AE HW: 8X0 919 475
Component: PARKHILFE 4K H03 0080
Revision: 11001001 Serial number: 37061533901478
Coding: 040102
Shop #: WSC 00046 412 12345
ASAM Dataset: EV_EPHVA14AU21X0000 003007
ROD: EV_AU210ParkAssis4K.rod
VCID: 091209ECA8AA537629-805C
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8XA 959 655 A HW: 8XA 959 655 A
Component: Airbag10.41 H08 0011
Revision: -------- Serial number: 003NZ000MYC0
Coding: 30314539313130323332554A305238584153
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 59B219AC588A63F659-800C
Crash sensor for side airbag; driver side:
Serial number: 3554VRB4002555N07OQF
Crash sensor for side airbag; front passenger side:
Serial number: 3575HRB404V3OMVO10SW
Crash sensor for front airbag; driver side:
Serial number: 3585HRB405T3OKICD1D3
Rear Impact Crash Sensor:
Serial number: 3515ZRB405V3K8QGO14E
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 521 AF HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: FF010018 Serial number: 20151207201464
Coding: 1894204000
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 000414C89B90123E7E-8054
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Component: E221 - MFL H08 0010
Serial number: 10 11 2015 C0026246
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8XA 920 980 HW: 8XA 920 980
Component: KOMBI_MEDIUM H06 0480
Serial number: 00000000000000
Coding: 41DE01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 0D1A3DFCDCC24F5605-8058
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AE HW: 8U0 907 468 J
Component: GAT 4CAN 2L M H13 0074
Revision: 1R160041 Serial number: 4141R15B210749
Coding: FBCF1057010301010153
VCID: 050A05DC8CB237164D-8050
Subsystem 1 - Part No SW: 8X0 959 591 C HW: 8V3 959 591 A
Component: J245 PS70.402 H03 0004
Coding: 901E00
Subsystem 2 - Part No SW: 8K0 915 181 L HW: 8K0 915 181 L
Component: J367-BDM H08 0181
Subsystem 3 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Component: J532_DCDCStab H23 0022
Address 20: High Beam Assist. (J844) Labels: 8X0-857-511.clb
Part No SW: 8X0 857 511 AA HW: 8X0 857 511 AA
Component: FLA H03 0005
Revision: AA001001
Coding: 02020E64747464545425363E00
ASAM Dataset: EV_HighBeamAssisAU210 001019
ROD: EV_HighBeamAssisAU210.rod
VCID: 7DFA6D3CEC627FD615-8028
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H06 0480
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415
Revision: -------- Serial number: --------------
Coding: 011E025C5C5C000100–Caused fault below to be logged.
Coding Original 011E02201C01000100
VCID: 52A0EE800D7C50AE98-8006
2 Faults Found:
00830 - Convertible Top Control Module (J256)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 6110 km
Time Indication: 0
Date: 2016.07.06
Time: 20:14:31
00380 - Special Vehicle Control Module (J608)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 6110 km
Time Indication: 0
Date: 2016.07.06
Time: 20:14:31
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6R2 909 144 AJ HW: 6R2 909 144 E
Component: EPS_TRW_ALow 322 3132
Serial number: CFCF0119
Coding: 800700
ASAM Dataset: EV_SteerAssisUDSTRW 016029
ROD: EV_SteerAssisUDSTRW_AU21.rod
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
Coding: 011E02201E01000100
VCID: 51A2E18C087A2BB6A1-8004
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 8X0 907 357 E HW: 8X0 907 357 B
Component: ****LWR12**** H02 0020
Serial number: 151214-0002-051
Coding: 11B1941010002500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 448CD8D8CF08CE1E1A-8010
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8XA 035 192 A HW: 8XA 035 192 A
Component: RMC Nav Plus H61 0139
Coding: 0101000100C053470023020103010000000000
VCID: 4688C2D0F134FC0E04-8012
Subsystem 1 - Part No: 8X0 919 884 J
Component: P32-50-15.03 0001
Subsystem 2 - Part No SW: 8X0 919 603 B HW: 8X0 919 603 B
Component: DU6 Basic H43 0084
End-------------------------(Elapsed Time: 03:15)--------------------------
Byte 4
Bit 6 Activate
Byte 4
Bit 6 Activate
Thanks in advance.
www.Ross-Tech.com
Revision: R6H23---
Coding: 0000020
Coding: 6420080880
Revision: AC113817
Coding: 02005D
Coding: 040102
Coding: 1894204000
Coding: 41DE01
Coding: 901E00
Revision: AA001001
Serial number:
Coding: 000002
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 6110 km
Time Indication: 0
Date: 2016.07.06
Time: 20:14:31
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 6110 km
Time Indication: 0
Date: 2016.07.06
Time: 20:14:31
Coding: 800700
