Audi 80 Sport (2L 8v) Tickover / Throttle Problem
aaronjt Nov 11, 2006
  1. aaronjt
    aaronjt New Member
    Hi there everyone, tis my first post so I'm sorry if I make any mistakes!
    I’ve had my Audi 80 for about 2 months now, prior to that it has been off the road for just over a year and a half. So after a few bits and bobs here and there it passed the mot no problems.
    Recently I have had a problem with the tick over, when I start the car it ticks over exactly where it should just below 1k. But when I give it a rev to about 2k it just sticks there for most of the journey. Its not the throttle cable as I had a look at that and its not slack or anything. I also recently replacement the coolant temp sensor so I don think that’s it.
    I took it too my local garage who cleaned the throttle body out but after a bit of a drive it went back to the same problem. Its worth mentioning that it will only over rev about 50% of the time, which is enough to be annoying!
    If anyone could shed some light on the problem or has had it before it would be a great help :)
    Thanks in advance
    Aaron
    p.s. If there is any other info I've missed out just let me know :)
  2. scotty33
    scotty33 Member
    155
    Sounds like your Idle stabilisation valve is sticking open. Kind of cylinder shaped object with a 2 air pipes and an electrical plug on it. usual fix is to spray carb cleaner through the mechanical end until it comes out clean, or soak it in petrol.
  3. niftyandy
    niftyandy Member
    100
    Could also be your Air Flow meter - it sits on the airbox....check the plug connections...If its stuck or not working it can 'strangle' the engine as no air flow data is getting to the ECU. Inside there's a butterfly valve or large 'flap' valve that should open letting air into the injectors....if the Air Flow meter's broken it'll cause this flap to remain closed and choke the motor.
    On the issue of the idle stabiliser valve...if you leave the ignition on and unplug/plug it in repeatedly you should hear it buzz and also the sound of it opening and closing the valve inside it, if its working that is!
    Good luck!
    Andy
