Audi 55reg quattro load vibrating at 2 thousands revs
bearder2006 Mar 1, 2010
  1. bearder2006
    bearder2006 Member
    205
    the bearing in the middle ?
  2. latta1989
    latta1989 Member
    147
    Cars apparently only done 40k
    ye apparently. The tech said they made it with some rubber bits or something an they can wear away.
    Didn't totally hear him was too busy drivin while he was talkin lol.
  3. cassf1
    cassf1 New Member
    14
    mine done 40000 as well
  4. crunchie
    crunchie Active Member
    880
    77
    32k on mine and its doing it, hopefully its just the centre bearing as Latta1989 says. can upgrade bearing to 07> item too hopefully.
  5. bearder2006
    bearder2006 Member
    205
    is hard to change the bearing ? what does it intail ?
  6. cassf1
    cassf1 New Member
    14
    Dont think the newer bearing will fit as its not just the bearing thats differant it the hanger ours bolts straight up above the prop on the newer ones the bracket bends down nad bolts under the prop
    To change the bearing the cv needs to be split then pull the bearing off using a bearing puller then new one can be put on, all parts of prop need marking to make sure the two halfs go back in the same position or will need re balancing also need to make sure the prop bolts back on the car in same holes
  7. sarah1989
    sarah1989 Member
    I'm experiencing a similar problem, but at 1400rpm, it just judders and vibrates.. mines a 54 plate 2.0tdi done 60k :(
  8. bearder2006
    bearder2006 Member
    205
    this really is a common problem sorry to here that sarah between us we will sort it
  9. sarah1989
    sarah1989 Member
    Mines going in to the garage tomorrow, does your car do it all the time or only when hot?
  10. bearder2006
    bearder2006 Member
    205
    alll the time
  11. B111COR
    B111COR Member
    My 56 plate 170 Quattro diesel with 25k on the clock does this, only just noticed as its the wife that uses it most, 5th/6th gear under load, when it happened, I asked her if she could hear/feel the vibration, yes she says, it does that all the time:tumble:
    Will get it looked at this week
  12. fizz
    fizz Member
    264
    Well mine went in today & they changed the propshaft. All sorted & no more vibration
    On a side note, the 10 plate A4 they gave me was very nice. Would like to see the start/stop, electric handbrake, keyless start & colour DIS imported onto the next A3
  13. bearder2006
    bearder2006 Member
    205
    was that under warranty fiz ?
  14. fizz
    fizz Member
    264
    Yes mate
  15. cassf1
    cassf1 New Member
    14
    There has to be an easier fix as i said the propshaft is only made up of a few parts (2 halfs joined by a cv, centre bearing and a damper) surely one of these must have failed not all of them its probs easier for dealer to change full prop rather than find the problem
    They would need to strip the cv joint to change the bearing and if they didnt join the prop in exactly the same place they would have to balance the prop which they do not have the facilitys to do same with the damper if they remove the damper they need to rebalance (which they cant do on site).
    So unless the propshaft has been bent or it has always done this from new, i guess it can only be the bearing or damper if i were to remove my own prop i would get it balanced for piece of mind and sake of £60ish
    This is just my thoughts tho
  16. cassf1
    cassf1 New Member
    14
    Fizz did the dealers go for a drive with you when u first took your car to them as it seems a bit strange they would have a prop sitting on the shelve unless this is a bigger problem than they letting on
  17. fizz
    fizz Member
    264
    No they just took it themselves & when they diagnosed it they said I was lucky as they had one in stock. I saw the original booking in slip and it stated that it was not part of a recall i.e known wider problem.
  18. Roswell
    Roswell Member
    311
    Our 55 2.0 TDI Quattro S-line had this problem. I got it fixed just before selling it a year and a half ago. Again it was the propshaft and it was replaced under warranty.
  19. crunchie
    880
    77
    hi mate, did the bearing fix the vibration? any information would be appreciated. thanks.
  20. latta1989
    latta1989 Member
    147
    cars going in on wed for repair so il find out more in detail exactly what they are doing to the car
  21. sarah1989
    sarah1989 Member
    I still have my problem which is just turning out to be a nightmare, just spent endless money on diagnostics and got no where!!!x
  22. crunchie
    880
    77
    that would be great, thanks very much. sorry to use you as a guinea pig lol.
  23. cassf1
    cassf1 New Member
    14
    sarah not sure if yours sounds like same problem i have never heard of one happing at so low revs
    unless ur bearing is loose or completely gone
    what have they tried/looked at?
  24. rickyquicky
    rickyquicky Member
    342
    Sarah, is your A3 a quattro?
    My mate was sitting in the passenger seat and thought he could feel the car 'vibrating' through the seat.
    Mines FWD so no propshaft etc.
  25. c_w
    c_w Well-Known Member
    1,163
    87
    It might be the balancing of the propshaft causing the vibrartion, since this is a very specialised procedure they just fit a new one?
  26. bearder2006
    bearder2006 Member
    205
    it is cheaper if your paying to have yours balanced your self
  27. latta1989
    latta1989 Member
    147
    Collected my car the other day and they have replaced the propshaft bearing. Appears to have cured the problem. Don't get the same noise anymore just the noisy diesel now lol.
    Asked the dealer how much it would cost not under warranty and he said about £400 ish.
  28. crunchie
    880
    77
    thats great mate, wont be getting it done at the stealers tho. robbing buggers that they are! thanks for passing the info on!
  29. Mr V
    Mr V New Member
    29
    If you look at the propshaft on the Haldex end, you'll see 3x 12point 10mm bolts that go through a rubber bush that holds the propshaft to the Haldex. On the outer surface of the rubber bush there's metal ring. The metal ring should be able to move slightly, backwards and forwards and return to the center position. This ring is the outer race of the bearing. What happens is over time that ring sticks and siezes causing vibrations when accelerating at about 50-60mph. A new - complete - propshaft is about £900 plus vat.
    HTHs
  30. cassf1
    cassf1 New Member
    14
    Mr V i think you are getting mixed up with at the haldex end it sounds to me that what you are referring to is the damper, the bearing is in the middle its on the CV joint between the two halfs of the prop.
    have a look here
    http://www.vagcat.com/epc/cat/vw/GOLF/2005/405/53/4004830/
    You need to register but its free
  31. crunchie
    880
    77
    had my mechanic inspect the centre bearing but nothing obviously wrong with it. going to order new bearing and fit it for starters.
    will report my findings.
  32. octadave
    octadave New Member
    I have same problem on octavia 4x4, i.e. vibration at 2100 to 2400 rpm accel or decel notably in gear 4, 5 or 6. The vibe is engine speed related so not propshaft balance. I checked with a friendly audi/vw specialist and it seems Mr V had it just about right. A few inches forward of the rear diff is a sort of doughnut with steel outer ring. This is the propshaft damper whose function is to reduce the torsional vibes from the engine. You should be able to grip the outer and move it a bit. If not it is seized. Mine is and it goes to the dealer under warranty later this week. Not sure if it means a new propshaft.
    Just to comment on vibration caused by out of balance propshaft, the frequency will be linked to road speed not engine speed. Back in the days of rwd, this was commonly due to worn universal joints
  33. Robo
    Robo New Member
    Hi, did you manage to resolve your problems by changing the centre bearing on its own? I had my propshaft changed 22 months ago under warranty and now the problem is back, only I am going to have to pay for it myself now so any pointers would be much appreciated.
  34. crunchie
    880
    77
    Money been a bit tight recently but i think i'll go ahead with the bearing and donught this month.
    Will post my findings.
  35. crunchie
    880
    77
    Hi. Did the new donught fix your problem? Garage tried to fob me off with a new propshaft at £1K!!!!
    I'd rather crash it into a wall! :L
  36. crunchie
    880
    77
    Got new haldex coupling today, £240 from Audi. Will fit it when im back form the rigs and let you know what the score is.
  37. Jonay
    Jonay Member
    274
    Got a 55plate 2.TDI QS aswell, and before reading this I didnt think it was much an issue.. I've got 113k on the clock and counting.
    So its definately the propshaft then.. :(
    Reading this thread it isn't very clear as to what the minimum work is required to fix this, nor is it clear the cost.
    I'm seeing ranges of solutions from changing the bearing only to replacing the whole propshaft.
    I'm not too sure if my car is under warranty, I've only just become the 3rd owner, how can i find out if it is? What invalidates the warranty?
    Costs, again ranging from £60 quid for the bearing to £2000 quid for the propshaft.
    Can someone summerise for the sakes of the thread please? :)
    I can probably stretch to £500, maybe £750 to get this fixed, but I don't know if this is the only problem with the car! (fingers crossed!)
    TIA
  38. crunchie
    880
    77
    113k!! YIKES!!! Mines been doing it since about 30k, its at 40k now. Will be 2 weeks till i get my haldex coupling replaced to see if it cures it. NEVER having another audi thats not under warranty! prices for parts are bearable but the labour is a joke! "vacuumed you car free of charge" my A*SE!!!!!!!
  39. crunchie
    880
    77
    GOODNEWS GUYS!!!!! Fitted my new haldex coupling today and all vibrations have gone!!
    Audi part no. - 1K0521307A @ £201 + vat.
    I bought the 6 bolts that hold it on also just to make the job easier.
    Took two of us just under an hour to fit and the best thing is that you dont need to split the prob at the centre bearing either. DODDLE!!
    Thanks to "octadave" who pointed me in the right direction.
  40. antmax7
    antmax7 Member
    295
    is it just a case of unbolt old one slide out,slide new one in and re bolt?
