Hi guys wonder if any of you can help me... I skidded in the snow other week and hit a kerb with front driverside wheel, I bent my steering rack arm and had to have a new one fitted,, had that fitted and then i had a grinding noise which was the hub,, so i replaced that and also the wishbone just incase that had been bent,, My wheel looks like it is not straight, it looks pushed in more at the bottom, what do you think i have damaged? i keep hearing a noise like a clunking ? do you thing the hub carrier may be bent or the actual leg my need replacing? If the leg is damaged i think i will just buy a coil over kit for it, so if any of you guys have the Audi A3 3.2 with a coil over kit on could you send me a link were to get one from..... Cheers guys... Are the Suspension legs the same on all the other 8P models?
Thanks Again.
Thanks Again.
