AUDI 2 BUTTON REMOTE ALARM FLIP KEY FOB
fallmonk Sep 13, 2009
  1. fallmonk
    fallmonk Turbo Sport
    1,868
    Hi Folks
    a quick question my 2 button alarm key has jammed down on the open button so anytime i go near car it opens and opens windows !
    Using stanadard key to lock its fine , cant really see any 2 button ones on ebay so my question is can i use a more modern 3 button one ?
    There seams to be plenty and are the internenerls easy to swap(transponder chip???) many thanks in advance for your help
  2. aragorn
    18,665
    880
    The key splits into two parts, one with the transponder and key, and the other has the remote part.
    Wether the 3 button will work depends on which remote locking pump you have at the moment afaik.
    old_skool knows a bit about these pumps, perhaps he'll be able to tell you which keys will work.
  3. Broken Byzan
    13,244
    468
    Kevs the man, i await the expert.I think it's 2 button for 2 button cars, if you change your pump you can run the 3 button type i think
  4. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    your original key is probably 4D0 837 231 ? sometimes on an orange sticker inside (there are others compatable but this is the usual)
    you can replace with 3 button type 4D0 837 231 A on a green sticker, the tailgate button wont do anything but the other buttons will work as normal
    as aragorn said the key / transponder part from your original fob will attach to your replacement button part,
    you say you have another key so you can code the buttons yourself without any special tools
    ive got a couple of spare 2 button fobs but there a bit shabby
    changing pump to a later spec one wont allow tailgate button to work and there not compatable with siren fitted in early cars
  5. fallmonk
    1,868
    Cheers guys found a guy on net who is selling a 3 button job that he says is suitable! PART NO...TEMIC-PHILS --8ZO 837 231 D
  6. olds_kool
    1,094
    15
    8Z0 p/n im fairly certain are for cars with electronic c/l (central conveniance units not pumps)
