audi 2.5tdi V6 timing belt change issues - lack of power
ms1083 Jul 13, 2013
  1. ms1083
    ms1083 Member
    148
    just completed doing my timing belt change. car runs smoothly, timing within spec on VCDS. Drives ok but lack of power - almost as tough turbo not working. Any help/ideas?
    Took front end completely off but sure i have reconnected everything.
    No fault codes.
    Could it be to do with the vacuum pump which has to come off to get timing tool in? What would happed if it is not making a vacuum? If this is a possible cause how do you test it?
  2. ms1083
    ms1083 Member
    148
    just noticed close to the vacuum pump on its hoze there is a T connector and 1 of the tiny pipes has snapped off its nipple. THis pipe leads to a box with lots of other vacuum pipes & electricial connectors - could it really be as simple as lack of vacuum getting to the turbo?
  3. wesmaster
    wesmaster Member
    300
    20
    Yep, vacuum controls boost and egr.
