Audi 1.8T sport saloon styling opinions
K7ERG Nov 27, 2007
  1. K7ERG
    K7ERG Member
    372
    I have a 1.8T sport and looking at a few styling ideas before the car gets a full respray.
    I have the RS4 bumper and i need to get a wing for the car, so looking at either a replacement wing or new RS4 wings.
    Keep it as standard
    RS4 bumper modified to fit standard A4 Arches.
    RS4 Bumper with RS4 wings
    Not sure if it will look any good with the front arches being flared and the rear standard.
    Opinions please
    Craig
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,778
    33
    Having flared fronts and not rears would look gash.
    Just get the RS4 bumper fitted into the existing arches. CliveH did this on his and it looks fantastic.
  3. Siena
    Siena Active Member
    2,626
    Will definitely look odd, with wide shoulders and slim hips.
    As BT said, RS4 bumper modified to fit A4 wings will look great.
  4. K7ERG
    K7ERG Member
    372
    Any pics
    My URS4 has wide front arches and standard rears.
    Craig
  5. Siena
    Siena Active Member
    2,626
    Aye, Craig. But that's standard on URS4/6. The A4 will look odd, especially due to the fact the sills are extended.
  6. K7ERG
    K7ERG Member
    372
    ok so how will i mod the genuine RS4 bumper to fit the standard arches.
    Best place to buy a Genuine front arch?
  7. Siena
    Siena Active Member
    2,626
    You'll need some patience, as well as a heat gun, not too hot though. A hair dryer will be fine. You'll need to bolt the bumper to the car, and slowly apply heat, and blend the sides to match the stock A4 arches.
    I have both front wings from my '96 A4 quattro. Let me know what side you're after, and where you are.
  8. K7ERG
    K7ERG Member
    372
    Pm sent
  9. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Here is an RS4 front bumper on the A4 arches.
    Here is the full RS4 front without the rears done.
  10. Siena
    Siena Active Member
    2,626
    Hmm, RS4 front wings lower section doesn't match up with stock A4 / S4 skirt.
    It looks unfinished.
  11. shineydave
    shineydave Member
    920
    to be fair we're not sure whether Clives bumper was modded or not, we certainly didn't mod it when we fitted it. as far as i can see the modding is to stop the underside of the bumper from becoming wavey. there was no marks on his to indicate it had been cut and rewelded that's for sure.
    it's a piece of cake to fit, you have to use the RS4 bumper mounts, grills, foglights and headlight washer covers. bin the A4 side bumper mountings as the RS4 bumper mounts direct to the inner edge of the wing. you'll also need to get your hands on some black plastic sheet about 2mm in thickness to make up some infill panels for the inside of the wheelarch and to get the bumper to line up with the wings we put some washers under the upper bumper mount bolts to angle the mounts down slightly.
    I'm sure Clive will be along at some point to post a couple of pics
  12. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Yeah it does look unfinished.
    They just did it on those A4/S4s for on the track.
  13. K7ERG
    K7ERG Member
    372
    so whats the best way to get the bumper to match the A4 standard arches?
  14. S4TAN
    S4TAN Evil Incarnate
    45
  15. docurley
    4,073
    88
    Heres a 1.8T with OEM RS4 bumper and S4 sides and rear bumper.
  16. K7ERG
    K7ERG Member
    372
    Nice!!!!
  17. macattax
    macattax Member
    455
    I much prefer the kit you have on your car in the sig Doc.
    What is it a rieger kit?
  18. Siena
    Siena Active Member
    2,626
  19. macattax
    macattax Member
    455
    I was talking about Docs kit is that an RS4 kit too?
  20. Danielson
    Danielson Member
    704
    doc is indeed running the oem rs4 front!
  21. Siena
    Siena Active Member
    2,626
    Aye, but not just the front - the whole lot, combined with a Euro S4 rear bumper.
