Audi 1.8t BEX complete engine
Steveo135 Aug 11, 2014
  1. Steveo135
    Steveo135 Member
    54
    As above, I'm after a complete engine for a 2003 A4 1.8t 190bhp BEX engine.
  2. Steveo135
    Steveo135 Member
    54
    Still looking for an engine guys.
  3. Steveo135
    Steveo135 Member
    54
    Still after an engine guys.
  4. davkav
    davkav Member
    166
    If your turbo is still good, would you not just get any 1.8T post year 2000 and swap over the accessories?
  5. Steveo135
    Steveo135 Member
    54
    Hi pal turbo is buggered also. What engine code should I be looking for as a replacement??? Will I have to put bigger injectors in also from the bex engine?
  6. davkav
    davkav Member
    166
    Yeah basically any 1.8T engine that has small port head and VVT will do the job. You'll just need a K03s turbo from the BEX then, probably easier to get a K04 hybrid. Your injectors that you have will need to be swapped over as well as they are slightly larger than the standard 150/165bhp models.
    Check out this link here: http://www.clubgti.com/showthread.php?34368-1-8T-20V-Engine-codes-FAQ
    So you want Small port head, DBW, Internal Water Pump and VVT in the head.
    What exactly happened to yours? Could your head be ok?
  7. davkav
    davkav Member
    166
    Just read you thread there regarding the oil pump failure. Your turbo might be ok...
    Id take it off any have it checked, you might get lucky.
    As for the engine, as I said above, id get one the engines that are listed in the link above. Then swap everything on the outside of the engine from your BEX onto it. Ancillaries (Alternator, PS etc) Intake and exhaust, all associated vacuum pipework...
    You will need the clutch and flywheel from your BEX as well as the ones from Transverse Mounted engines (golf, a3) will not work with your gearbox.
    Basically you want the block and head from a different car and then swap EVERYTHING from your engine on to it.
  8. Steveo135
    Steveo135 Member
    54
    Hi pal thanks, I have managed to get an APU engine from a friend complete. If I put the turbo off the bex on this engine do I need to keep the standard injectors on the APU. Also will I need to remap the car or should it run fine with it being mapped for bigger injectors???
    Thanks again for your help.
  9. davkav
    davkav Member
    166
    Good stuff. The only things you want from the APU are the head and the block. Id swap everything else over from you BEX, injectors and all.
    You wont need a remap as long as you keep the BEX turbo and injectors.
    Whilst you have the APU engine out Id drop the sump and throw in a new oil pump pickup. Don't bother trying to clean the one thats there for the sake of a £30 part. You may aswell throw on a new timing belt and water pump as well whilst you are at it. Probably not an expense you had budgeted for but will save you money and time in the long run. With the engine on a stand you could easily do it yourself.
    Quick list off the top of my head of what gaskets/seals/parts you will need:
    Intake Manifold Gasket
    Exhaust manifold gasket
    Turbo return line to sump gasket
    2 copper washers for the coolant supply from block to turbo line
    Oil Pump pickup
    Timing blet and waterpump
    Thermostat housing gasket (housing is different to the Passat APU one)
    Oil filter hosuing to engine block gasket
    Rear Coolant Flange (located at the back of the head)
    When you are removing the turbo, only disconnect the oil and coolant lines from the car; don't bother removing them from the turbo.
    Just on a side note, the APU is from a manual car right? the cranks are different between the Manual and Auto cars.
  10. Steveo135
    Steveo135 Member
    54
    Hi pal the engine isa manual, will I need the clutch/ flywheel from the APU or BEX
    Again thanks
  11. davkav
    davkav Member
    166
    Use the clutch and flywheel from the BEX.
  12. Steveo135
    Steveo135 Member
    54
    Hi bud, thanks for the help so far. I have come across a little problem tonight, the APU engine I have the water pump and the thermostat are located in different place within the block, than the BEX engine I have removed. The engine I have had a viscous fan on it etc and water pump pulley next to it. The bracket and alternator will not align with the APU water pump where it is situated . Hope that makes sense.
    Steve
  13. davkav
    davkav Member
    166
    Hey Steve,
    That engine won't do the job I'm afraid. That engine is whats called an 058 engine and came from a pre 2000 car.
    You need an 06A engine that has an internal waterpump the same as your BEX.
    Dave
  14. Steveo135
    Steveo135 Member
    54
    Ok pal. So is it still the APU but from a newer model???? Thanks again.
  15. davkav
    davkav Member
    166
  16. Steveo135
    Steveo135 Member
    54
  17. davkav
    davkav Member
    166
    Well I had a quick look there and here are a few engine codes that will do the job:
    AJH AMB AMK APP AQX ARX ARX AUM AUQ AWP BAM BEX BFB BFV BJX BVP
    If you come across an engine code that I haven't mentioned, sure PM and Ill check if it suits.
    PM before you buy any of the above as well. I am 90% sure they are the right ones but if you find one of them let me know and I will make 100% sure. I have the Audi/VW parts system here so I can make sure for definite.
    Dave
  18. Steveo135
    Steveo135 Member
    54
    Hi Dave
    I have been offered either a AUM or AQU. Code you possibly check comparability etc.....
    Again thanks for the to date.
    Steve
  19. davkav
    davkav Member
    166
    Hi Steve,
    Sorry for the delay in getting back to you.
    The AUM will do the job perfectly. Exactly what you want. Internal waterpump, VVT head and small port head.
    Dave
  20. Steveo135
    Steveo135 Member
    54
    Hi dave
    Can I ask another question my pal has a
    ARZ engine complete would that do also.
  21. davkav
    davkav Member
    166
    Afraid not man, as it has no VVT in the head.
  22. World Deals
    World Deals New Member
    Contact 07722574951 if ur interested in a 1.8t slide engine
  23. World Deals
    Sline
  24. davkav
    davkav Member
    166
    No such thing as an sline engine
