attaching jetex filter to maf?
m8arx Jan 6, 2011
  1. m8arx
    m8arx Member
    176
    whats the best weay to do this?
    Use a coupler to extend it a little - if so, what size diameter coupler will do?
    or just attach it straight to the MAF? if just straight to MAF - will the filter jand i just slide over the MAF and i can jubilee clip them together?
  2. jay1601
    jay1601 Well-Known Member
    1,312
    57
    jubilee clip straight onto the MAF :)
  3. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    use a coupler and put it closer to where the standard air feed is. if u have an s3 it is 80mm to 80mm on an A3 its 80mm to 70mmi believe
  4. Prawn
    11,446
    3,340
    depends on which filter you've got mate.
    I got the 80mm filter, wanting to future proof myself if I upgrade to a 3'' MAF with a hybrid turbo.
    So I'm using the biggest jetex filter with the 80mm neck, then an 80mm alloy coupler, then an 80-70 reducer from Bill which takes it close to the wing.
  5. DaveA3
    2,370
    15
    i have that same setup
  6. m8arx
    m8arx Member
    176
    it's an s3 i have guys, and the filter is 80mm i believe (its the one that bill supplies) so this means i won't be able to just slide it on if the maf is also 80mm :(
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    YES it will fit straight on to your MAF
  8. DaveA3
    2,370
    15
    the MAF is 80mm and so is ur filter. it will fit but will be in the hottest part of ur engine pretty much lol
  9. higher1
    higher1 Member
    mine is a s3 with the 80 mm filter fitted straight onto the maf with just the jubilee clip its a perfect fit
  10. m8arx
    m8arx Member
    176
    excellent - cheers folks :)
  11. Plunky
    Plunky Member
    522
    do you guys not find the filter vibrates a lot with the movement of the engine/car?
    I have heard strong vibrations can defect the MAF? is this true?
  12. Prawn
    11,446
    3,340
    if you look at mine Liam, the filter is actually tight up against the original airbox mounting tab on the inner wing.
    It kind of sits under the top of the tab, which stops it rising, and I expanded the coupler right out putting the whole lot under tension before tightening the clamps so it's actually dead tight in there!
  13. Plunky
    Plunky Member
    522
    cool dude, i'll have to have a look.
    Off to protyre tomorrow for some new rubber :)
