ASS retrofit
oufc1976 Apr 2, 2014
  1. oufc1976
    oufc1976 Member
    237
    82
    Anyone had it done?
    After a little under two weeks of ownership I've come to the conclusion that the standard audio system is a HUGE disappoinment.
  2. RossR
    RossR Active Member
    501
    122
    43
    I'd see if you can find a cable/connector in the boot for the sub. If that's there I wouldn't think it'd be too difficult. Probably cost a fair bit though so might be better going after market?
  3. jongeddes
    jongeddes Member
    57
    10
    Have you listened to it wondered how much different it was. I asked re retrofitting when I was looking at options and there was a lot more to it than just 2 extra speakers, there was amp and something else from what I remember. So as agreed might be better going aftermarket.
  4. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,578
    1,175
    I think it would be quite expensive. You'll have to take the whole dash apart to install the centre speaker, cabling everywhere, new pillar and door trims for the extra speakers in those where appropriate, and the amp itself which is placed under the passenger's seat.
  5. slipped_disc
    slipped_disc Member Audi A3 S-line owners group Manual
    74
    25
    A couple of cars ago I had a Vauxhall. Fitting the centre speaker just required you to pop the speaker grille off, find the cable and plug, connect it and screw the speaker in. If you were lucky, the Audi wouldn't be much more complicated.
    It will take someone to go hunting to see if any of the cabling is already in place...
  6. oufc1976
    oufc1976 Member
    237
    82
    Thanks for the replies. I've asked my stealer to get me a price...will let you know.
  7. cemerson
    4,578
    1,175
    This site has the B&O as a £1895 cost for retrofitting - B O Sound System and Speaker Upgrade Supply Fit Bang and Olufsen
    I would imagine it'd be a bit less than that. If you take the cost difference from ASS -> B&O off, assuming the options are priced on part costs only, you get about £1400, so that'll be my guess. From a dealer I'd imagine they charge a bit more though!
  8. oufc1976
    oufc1976 Member
    237
    82
    Ouch!! Sod that!
  9. slipped_disc
    74
    25
    If you've already contacted your dealer, it may be worthwhile getting a cost just for the required parts and thinking about fitting them yourself. I'd be interested in knowing what additional parts are required for the ASS.
  10. cemerson
    4,578
    1,175
    Yes, I suspect a large part of that cost will be labour & fitting, which can be vastly reduced if you're willing to do it yourself.
  11. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    6,202
    1,834
    Not listed for the 8v A3 though...
  12. cemerson
    4,578
    1,175
    A3 8V - 2012>
    3rd row, 1st item
  13. cuke2u
    6,202
    1,834
    I am looking at the drop down box where I see no A3 is listed....
  14. h5djr
    9,440
    1,757
    Well I can see it with no problem...
    Go to www.hazzydayz.com
    Choose AUDI from the top of the LH column
    Then it's the seventh entry down - A3 8V - 2012>
    B+0 is the 3rd row - 1st on the left-hand side
  15. cemerson
    4,578
    1,175
    Yes, there's obviously an error there. But it's listed on the page for the A3 8V, and I was only using it as a guidline for price anyway.
  16. oufc1976
    oufc1976 Member
    237
    82
    Dealer have stated its not available retrofit.
    Probably just can't be ***** to find out for me
  17. h5djr
    9,440
    1,757
    Try this address:
    A3 8V - 2012>
    It goes straight the 8V 2013 page. The B+O is third row down - 1st on the Left.
  18. cuke2u
    6,202
    1,834
    Yes I am doing that, however when you go to that page and click on the drop down 'please select model' there is no A3 listed...
  19. Vertigo1
    Vertigo1 Well-Known Member
    3,631
    725
    And totally void your warranty.
  20. cemerson
    4,578
    1,175
    Only as far as the part you've modified goes. If something were to go wrong with the entertainment system and your retrofit was found to be the cause then it would void the warranty for that, yes.
  21. h5djr
    9,440
    1,757
    Perhaps they have decided it's not a viable option to fit to an A3. Seems silly when you have already chosen the A3-8V 2012> and then not to list the model at the bottom of the page. Phone call required I think.
  22. Vertigo1
    3,631
    725
    They'd be within their rights not to honour any warranty claim on anything electrical to be honest, and I wouldn't blame them. Sure, if something purely mechanical broke which couldn't be linked to the retrofit then you'd likely be ok but then most cars are pretty bulletproof mechanically these days and it's usually the technology which goes wrong. If you've been messing with the electrics then you'll be on shaky ground and, if Audi are faced with a four-figure bill for a warranty claim, I doubt they'll think twice about wriggling out of it on those grounds.
  23. cemerson
    4,578
    1,175
    Is it? I think it's the other way around. Mechanical parts wear out and get fatigue!
    Either way, if you can get an independent expert to sign to say that your retrofit didn't cause the issue, Audi would struggle to deny the claim. If it didn't cause the issue, it would be against the law to deny you your warranty on something like that.
  24. cuke2u
    6,202
    1,834
    Thats what I thought...
