Ashtray delete/non-smoker tray retrofit - Pic heavy
MartayMcFly Mar 4, 2012
  1. grimp
    grimp Member
    142
    14
    Did this mod on my 8p3 the other day, didnt even have to remove the grabhandles, i used a socket and extender to loosen the one under the climatecontrol and the two in front of the shifter and just pushed the rubber within the gap :)
  2. Granta
    Granta Active Member
    293
    62
    Nice! Simple and effective!
  3. lgooch
    lgooch Well-Known Member VCDS Map User
    1,181
    162
    looking to do this when I get my hands on the wifes black edition. (waiting for plate change)
    currently the top of the ash tray is damaged and this extends into the black glossy trim on the gear lever.
    Can the black trim be replaced or is it a whole new leather gaiter, gear nob and trim combined ?
  4. RS3dan
    RS3dan Member
    178
    23
    Sure the gear surround is separable from the gaiter etc as you can swap them out for the brushed aluminium or piano black - whether or not you can get the trim on it's own from audi I am not sure, but I've seen it sold separately in the classifieds and elsewhere fairly often
    lgooch likes this.
  5. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,459
    597
    I have the ashtray delete insert for sale if anyone is interested, never fitted - pm me please
    lgooch likes this.
  6. lgooch
    1,181
    162
    PM sent. I also don't think you can just buy the ashtray lid can you ?
  7. lgooch
    1,181
    162
    Damn
    Immediate help required.
    Got the grab handles off and want to take the air con unit out.
    I have compressed the clips either side and the bottom of the air on unit is loose on the bottom but I just can get it out. It seems it is held in at the top as well. I have now tugged it too hard and I got it stuck.
    Any help before it goes dark on how to get this damn thing out ?
  8. lgooch
    1,181
    162
    All sorted. Just gave it a FBY !
    Just need to figure out how to sort the storage bin light out now. Got the light but no way of attaching it to the underside of the air con unit
  9. lgooch
    1,181
    162
    So I have the light bar at the top but no way of attaching it.
    I need to buy the trim at the bottom of the pic. However what's the loose reflector bar in the middle. Do I need this as well ?
  10. Chris Eaton
    Chris Eaton Member
    85
    25
    Thanks for this thread. It was a great guide !
    This is mine !
    Kelza likes this.
  11. MattS5
    MattS5 Active Member
    619
    60
    I assume this would be the same process for the DSG equipped cars? (does the gearstick surround just pull out as per the manuals?)
  12. Sayam
    Sayam Well-Known Member VCDS Map User
    2,712
    636
    Yes open the ashtray and pull the surround up from the front
    MattS5 likes this.
  13. andyz
    andyz New Member
    hello everyone, just started the ashtray removal and when I took out the aircon unit a flexiable spring type thing came off too. It's what diverts the blower to windscreen, feet or vents etc.
    Any idea where this might plug into? I'm fginding it very hard to see :(
    Great site by the way, I'm lesrning far to much which is definitely a dangerous thing....
    Many thanks
    Andy
    Sandra likes this.
  14. owenjt
    owenjt Member
    118
    Can anyone tell me if the part number quoted for the tray (8P0 863 301 A) will fit my 2010 8P3? Phoned the dealer today and they said it wasn't the right part.
    Also they couldn't find the 12v socket with flap on the system (8P0 863 387 A) - is that the correct part number? And is it a complete unit or just the trim?
  15. sebseb8
    sebseb8 New Member
    13
    You've got the correct numbers, the tray has 4PK on the end and the 12v socket has 6PS on the end. I think they both mean black. I've just fitted both to a 2008 facelift a3.
    The socket is the complete unit not just the trim.
  16. owenjt
    owenjt Member
    118
    Cheers - think I've managed to order the correct ones through the dealer now so will see when they come next week.
  17. Larschr
    Larschr New Member
    I performed this mod on my 09 8pa, I really like it. Nice with some extra storage room. Thanks for making this guide :) Best regards
  18. owenjt
    owenjt Member
    118
    Great guide - just done mine without any issues and looks so much better and now I have somewhere to put my wallet etc!
    Reading up about the red ambient lighting for this, am I right in saying that you just need to order part no 8P0 864 138 A, then slot it in and hook it up to the old ashtray connector?
  19. jordann
    jordann Active Member
    167
    31
    After seeing this thread I decided to get one, I fitted mine on Monday night. Although you can't really see it in the photo I already have the red ambient light below the air-con unit.
  20. Chris Eaton
    Chris Eaton Member
    85
    25
    I ordered the correct connection for the light in the ashtray and connected my own LEDs to it. From there I wired in a hidden switch and footwell lights
    (The centre light isn't as bright as it looks in the picture. Rubbish camera !)
    s3_trev likes this.
  21. whinfs
    whinfs Member
    58
    thankyou to MartayMcFly for the original how-to. ive just done this,but wouldnt have attempted it without the pics.
    i didnt need to remove the climate control - it was a bit fiddly but i had a socket extension long enough to reach the bolts
    thankyou :thumbsup:
  22. RS3dan
    RS3dan Member
    178
    23
    Is that an aftermarket HU? How do you find it, and which one is it? Does it have S/N?
  23. Lukeyb
    Lukeyb Active Member
    397
    53
    Been looking for the part number for this for a while, short of dismantling the gf's dash, which she wouldnt let me do. I managed to pop it into place and get the sides popped into their grooves under the side knee bars without taking them out.
    Wallet and phone fit perfectly :D
  24. yorksphil
    yorksphil New Member VCDS Map User
    25
    a3 ash tray light.jpg Just done this mod, and now have somewhere to put phone etc....
    So it's done but what about the light , i am thinking..... so i takes the led and diffuser out of the old ashtray (even a red led )
    And glue the led to the diffuser and strengthen it on the corner using heat shrink to support it resulting in this (piccy).
    so all i've got to do is pull the wires and plug from the ashtray position upto the back /bottom of climate controls and find somewhere to cable tie it and i have a light.......
    Looks underneath climate controls for a location......... and i see a lens/ diffuser! damned thing already has one!!!
    So if anyone needs an led to light up their's... i have one of sorts, and it plugs straight in!
    maybe i should have noticed that i have the interior light pack, and checked first before making something!!
    All good fun i suppose!:whistle2:
  25. dark_adi
    dark_adi New Member
    Hi, could You tell me what's the p/n of this B2D6DF9C-2B32-4779-94C1-B157D063E178.jpg
    I would like to have one but couldn't find.
  26. Lukeyb
    397
    53
  27. MattS5
    619
    60
    Great write up. Thank you.
    Just did mine this evening. Couldn't get the air con unit out, but it doesn't have the credit card/coin holder like in the guide.
    I just used an extension bar to get at the back bolts, no bother.
  28. Chappie99
    Chappie99 New Member
  29. Raffaz
    Raffaz Member
    69
    Great guide, bought my part from Stoke Audi and fitted it yesterday. Didn't need to take aircon unit out. I managed to access the bolts at the back without any problems :)
  30. jordann
    167
    31
    I'm sorry to bump such an old post but i've done the ash tray delete myself, which i'm pleased with. Ideally i'd like todo the cig lighter as well. This may sound like a crazy question but it doesn't remove it all together does it? On occasion i'd still like to charge my phone/sat nav.
    Whats the part number for the cig lighter delete? Roughly how much does it cost & how much of a pain was it to fit?
    Thank you in advance, sorry for all the questions.
  31. lgooch
    1,181
    162
    No it does not remove it altogether. It just simply makes it a flush fit and you open the flap on the top to plug in whatever you want to charge
    jordann likes this.
  32. jordann
    167
    31
    That's good, I didn't think it would but I just wanted to double check. I think in any case this mod looks better than having the cigarette lighter plug hanging out, Audi should have fitted this as standard.
    I don't suppose you or anyone could enlighten me as to the correct part number & cost? Also was it fairly simple to fit?
  33. MattS5
    619
    60
    Peice of cake to fit. Just pop the cover off near the handbrake and put your fingers under that trim to pop out the cigarette lighter from the clips on the inside.
    Swap wiring plug from that socket to the new socket, all done.
    5 mins at the most.
    Cant help with part number, I just sold my car today and gave all the paperwork away with it.
  34. MattS5
    619
    60
    and the part number is 10 posts above this one!
    8P0 863 387 A 6PS
  35. jordann
    167
    31
    Thank you for your help buddy :icon thumright:
    For anyone who's interested i've just spoken to my local deal and the part cost is approximately £23.
  36. bennyball
    bennyball Member
    138
    24
    Guys I can't work out which part I am missing, can someone advise please?
    I have already fitted the ashtray delete but i'm after the light and trim.
    I have bought these parts but i'm missing the light itself:
    A8P0 858 433
    A8P0 864 138 D4 PK
    A8P0 864 249 A4 PK
    Thanks in advance
  37. Ceylon
    Ceylon Member
    55
    14
    Did this a week or so back, fits my phone and wallet in nicely, much better than the ash tray!
    [​IMG]WP_20150122_18_31_27_Pro by Tom Kinsman, on Flickr
    [​IMG]WP_20150122_18_34_51_Pro by Tom Kinsman, on Flickr
    The trim piece is 8p0864138a4pk
    The LED and light guide is 8p0857355
    bennyball likes this.
  38. bennyball
    bennyball Member
    138
    24
    Thanks mate
  39. pint-of-mustard
    pint-of-mustard Member
    Thanks for the guide and pics. Did this yesterday and happy with the result, nice and cheap too.
  40. lgooch
    1,181
    162
    struggling with this a little bit.
    I have done the ashtray delete but just cant see how the light affixes to the trim underneath the air con unit
    I have the light which is part no 8PO 857 355 but no way will it clip under the dash. I had a look at my other A3 which has this from factory and it has a separate cover with another light lense which I don't have the in the car I want to do the mod to.
    See pics
