armrest removal, please help
fuddyboi Sep 13, 2013
  1. fuddyboi
    fuddyboi New Member
    12
    need to remove my centre arm rest and its stuck solid, have been searching online and found a pdf and they all say undo a m8 allen bolt i think it is, this is connected to a swing arm type section, once removed you pull the arm rest up and its removed however after removing this bolt i get nothing! the armrest wont move etc feels like something more needs removing, not sure if its ever been out before would guess not and so have been a little rough with it incase 13 years of grime is keeping it in place. i only need to remove the armrest not the bracket as i need to remove my centre console for a bit.
    has anyone had this before? really ned to get it out for a while
    thanks
  2. Prawn
    11,455
    3,351
    once the bolt is in the way the little gate should just swing across and it pops out upwards mate.
    Perhaps try prying the gate with a screw driver or similar?
  3. fuddyboi
    fuddyboi New Member
    12
    the gate thing you refer to how far should it move? i have maybe 90 degrees of movement, should there be more?
  4. fuddyboi
    fuddyboi New Member
    12
    never mind, we shared a few select words and then it came out ha ha thanks very much
    Sandra likes this.
