Armrest LED's
alpesh26 Aug 3, 2011
  1. alpesh26
    alpesh26 Active Member TeamMisano
    399
    35
    I've managed to source a front centre armrest for my A4 and it has the lead which powers the little red LED. As I will be retrofitting the armrest, where would be the best place to get power to the LED (ideally without having to remove the whole centre console)?
    The catch was broken and missing on the armrest so I used those magnets you get for kitchen cabinets and made a magnetic catch :p. It's not very OEM, but it does the job!
  2. Farhan
    Farhan Active Member
    1,234
    57
    not sure how your dash is, but the cig lighter feed seems a good point. On my A3 im planning to fit something similar but we are taking the feed from the cig lighter because it will illuminate when my sidelights automatically go on. (Cig lighter is linked to interior lights and sidelights so the bezel around it illuminates when the lights come on)
    You then need to just ground a wire to a bolt on the chassis or again you can use the ground for the cig lighter.
  3. alpesh26
    399
    35
    I was thinking cigarette lighter too. There is a panel in the recess for the handbrake which may reveal some wiring. The vehicle the armrest came out from had a lead coming from further down the centre console but I couldn't trace the wire down far enough
  4. Farhan
    1,234
    57
    Can you grab me a photo of your cig lighter and possibly a generic view of your dash. That way i can see of any routes to feed the wire.
    My cig lighter unit is pretty simple to remove, I just take the lighter out and tug at the holder and it reveals the wires.
    For connectors you can use scotch connectors which are the easiest, Just means placing the cig lighter wire in the scotch connector and the new led wire and pushing the connector closed. It will shave a bit of the wire casing off and make a good safe connection.
  5. alpesh26
    399
    35
    Just taken a few pics, the quality isn't great (underground car park and iPhone camera)
    Does anyone know how to get the cover off from underneath the handbrake handle?
  6. Wrath
    Wrath Well-Known Member
    1,196
    41
    I might be wrong but isn't access done by removing the rear ashtray (it just pulls out)?
  7. alpesh26
    399
    35
    Yes it is for the mounting bracket, i'm trying to get access to the electrics of the cig lighter to power the armrest LED. I'm also extremely jealous of your car Nathan!
  8. Wrath
    1,196
    41
    Cheers mate, I'm flattered. I'm sure it won't take you long to get your car looking like mine :laugh:
    Nothing under the front ashtray? Failing that I assume you have to remvoe the centre console.
  9. alpesh26
    399
    35
    It's getting there, bit by bit... :happy:. I'm thinking RS4 RARB next or maybe a Votex diffuser
    Good point, I has the front ashtray out to wrap it and I remember pulling off a connector as there is a little LED inside the ashtray, i'll tap into that and pull the cable through. Cheers!
  10. hades-
    9,481
    646
    front ashtray or cig lighter
    i usaly got for the ashtray
  11. Wrath
    1,196
    41
    I thought about the Votex and couldn't make up my mind. However, you can't go wrong getting an RS4 RARB :)
  12. auroan
    auroan Active Member
    1,669
    There is already a feed there for the armrest...... well there was when I retro fitted mine
  13. alpesh26
    399
    35
    I had a quick look last night but couldn't find anything, I took off the gear stick surround, the little hatch in the recess under the handbrake (this pushes out from behind in case anyone wants to know) and the velvet mat in the storage area but there was no spare leads/connectors...typical Audi consistency :shrug: . I'll tap into the ashtray light wires and feed it back, might as well feed my ipod and aux wires whilst im at it!
  14. auroan
    1,669
    Mine was tucked away infront of the rear ashtray. Only found it after I had the centre tunnel console up.
  15. Ash187
    7,478
    735
    what does this LED look like in the Arm rest? im quiet curious as i have just done my Footwells and under the climate control unit with red ambient leds that light up at night when the lights are switched on.
  16. NHN
    29,327
    1,708
    TBH its usually there tucked away incase spec'd as mine was, but if not take it from ashtray, coat hanger, sorted.
    As for how it looks, its a nice addition tbh, bright enough to see whats in there, on my list as are the other 1000 things lol.
  17. Ash187
    7,478
    735
    LOL!
    oh my armrest was retrofitted so i doubt i would have any wires going there... i have some Red LEDs left over from the other installs i was doing so could just find a way of mounting it in the arm rest. was also thinking i could even have one under the armrest to light up the cup holder area??
  18. NHN
    29,327
    1,708
    Sorry should of been clearer, I meant was in my S4 B6, its not part of the 8P, sut could retrofit it as I did to my S4 as armrest didnt have so bought & made it fit :)
  19. Ash187
    7,478
    735
    did you buy the oem LED unit or did you just fit in a red led and mount it (drill a hole for it)?
  20. NHN
    29,327
    1,708
    Grabbed an oem version before I sold the armrest it came on lol.
  21. alpesh26
    399
    35
    I'll try and get a picture of it tomorrow in the dark if you want. How did you get the lights under the climae control? Is it just an A3 thing?
  22. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    Can you also post pictures of these mods .
