Armrest LED connection ?
ADC74 Feb 24, 2012
  1. ADC74
    ADC74 Member
    155
    Just got my OEM armrest of the bay & I've noticed that it has the LED light installed. Now the armrest has the obvious connection plug but upon installing the mounting bracket I can't find any electrical loom / socket in which to complete the connection :search:Should there be a connection already on the car or do I have make one ?Any help would be appreciated :thumbsup:Just for reference my car is 2002 A4 B6 2.5 TDI SPORT AVANT.
  2. jbcalvin
    jbcalvin Member
    690
    21
    I had to make a loom up for mine, used the lighting wires from the cig lighter and just spliced into them.....
  3. benjie
    benjie Well-Known Member
    1,223
    304
    And the OEM wiring connector you need can be found on B5 A4 and A3 8L rear number plate lights - the connectors are the same.
  4. ADC74
    ADC74 Member
    155
    Did you have to remove the centre console to gain access to the cig lighter loom ?
  5. jbcalvin
    jbcalvin Member
    690
    21
    If you want to run the loom through the harness then yes, I had the centre console out anyway as I was fitting an RNS-E at the same time.....
  6. alpesh26
    alpesh26 Active Member TeamMisano
    398
    35
    I wired mine to the front ashtray light, the cig lighter looked tricky to get to. Just another option for you
