Armrest catching handbrake...
SCHOLESY83 Dec 12, 2012
  1. SCHOLESY83
    SCHOLESY83 Member
    42
    Anyone know how to stop this? Can I adjust the armrest so it doesn't go as low? Handbrake doesn't seem to be high or anything, 2-3 clicks to lock it on.
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    does it not adjust from the button/catch at the front?
  3. fangio
    fangio Well-Known Member
    1,521
    184
    With handbrake off, put armrest right down then lift to desired position....;)
  4. Artimus
    Artimus Shortback
    2,017
    485
    Well catalogued Audi design curiosity! you'll find it filed alongside door electrics shower on opening window after rain. :)
  5. SCHOLESY83
    SCHOLESY83 Member
    42
    Haha!
    and yeah, u can lower then lift slightly but that's just sloppy for them to miss that clash. As a matter of fact it's already started to scuff the handbrake leather, Nice!!
  6. fangio
    1,521
    184
    ????? No, it locks in position up to too high for comfort, but it must go as low as possible before you lift it or it won't lock!!!!
  7. MarkMS3
    MarkMS3 Member
    35
    Mine has a sweet spot when i lower it right down then lift maybe a half centimetre or so then push down it locks just high enough to miss the handbrake
  8. SCHOLESY83
    SCHOLESY83 Member
    42
    Yeah I get what your saying, my point being that its naff that it clashes with the handbrake full stop, should be free of clash no matter where in its travel range it is.
    from the response it's not just mine. So I guess I'll just have to live with it.
  9. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,766
    355
    Mini mirror sun-visor on the one hand, no armrest/handbrake congruity on the other. I guess some of the engineers at Audi are more equal than others.
  10. Zak0123
    Zak0123 Active Member
    540
    77
    When I first got in my car after buying, the salesman even identified it as a design flaw. It's no inconvenience though, as Mark says just lower it all the way down then lift it up one notch so it sits parallel to your forearm.
  11. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    I always lift my armrest to fully apply the handbrake! Then return it down...
    Don't do what my cousin did with her brand new 1 day old Audi A3 S-line...
    She parked on a hill, applied the handbrake till it touched the armrest. Woke up next morning and found her car gone but did see a brand new 62plate A3 that had wiped out a wall, a tree and in the pond at the bottom of the road. Total write off. Oh and it was a company car. Bad day.
  12. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    That is doing my head in! I didnt notice it early enough and now I need to replace the handbreak leather trim as its worn down quite a lot on the edge where armrest was touching against it.
  13. fangio
    1,521
    184
    My last reply wasn't worded properly!
    The armrest can be locked FROM a position too high for comfort, in steps, right down to the console. i.e. right down, lift a bit and lock, lift a bit more and lock and so on.
  14. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,063
    572
    after seeing this on my car i got those self adhesive patches that you fit on furniture. the softer one.
    cut the small piece and glued it under the armrest. it helps...
  15. Lewis583
    956
    91
    Don't forget their ingenious idea to put a drinks holder above the radio/climate control panel :think:
  16. Artimus
    Artimus Shortback
    2,017
    485
    They outdid themselves with the 8P holders by putting them under the armrest and making them small & extra-small, so you can't put anything in them taller or wider than a can of coke & use the armrest at the same time! Any bottled drinks have to lay in the door pocket. :think:
  17. Cruiser89
    1,484
    222
    But they did make the hole big enough for a can of red bull :p
    RedDejavu and Artimus like this.
  18. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,488
    633
    I have been driving A3/S3 for the last 6 years and its now habbit to lift the armrest before applying handbrake.
