  1. STERLING VOID
    STERLING VOID Active Member
    145
    I am struggling to get my arm rest in the centre console to click on the second level, what is the trick to doing this?
  2. Schizophonic
    Schizophonic Well-Known Member
    975
    490
    Make sure the arm rest is at the lowest level. You just lift up to the desire height and then it just locks into place.
  3. frazzeld
    frazzeld Active Member
    146
    27
    on an angle?
  4. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,614
    1,194
    You just pull it up to the height you want, that's it
  5. Jeff777LUFC
    Jeff777LUFC Member
    84
    12
    If its not locking in place you need to raise it fully, then close it again. Then when you raise it again it will stay in place.
  6. Schizophonic
    975
    490
    Yeah what I learnt was that if it was in the desire hold position and if you need to readjust you need to push it all the way up, back down and up to the desire height.
  7. frazzeld
    146
    27
    My arm rest slides forwards, backwards and raises on a slight incline.....is mine different to others?
  8. Schizophonic
    975
    490
    No, there isn't any other options. It should be all standard. What Jeff said above is the correct procedure to lock the armrest into place.
  9. STERLING VOID
    145
    Thanks Guys
  10. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    963
    397
    Mine works as per the posts above; lift from lowest position to desired position. Then lift it to top to allow it to go all the way down.
    However, can't get mine to go forwards/ backwards. Is there a latch for that? Tried the user manual. In case it makes a difference, I am S-tronic.
    Sterling Void - glad your original query is sorted.
  11. STERLING VOID
    145
    Thanks mate, you need to slide the top part of the arm rest forward, just the lip part. This should be standard for all.
  12. JohnM100
    963
    397
    Fab thanks. I wasn't pulling it hard enough as did not want to break it......
    John.
