Arm rest squeak?
sting3r Dec 8, 2011
  1. sting3r
    sting3r New Member
    26
    Anyone elses center arm rest noisy? Mine squeaks loads when i go over small bumps etc or move my arm slightly to change gear. Its just a general squeak from the whole thing moving within the center console, so not sure there is a lot that can be done, but does anyone have any ideas?
  2. vw754
    vw754 vorsprung Durch Technik
    2,321
    58
    remove the rear ashtray and check if the bolt is tight for the armrest
  3. rOb_A
    rOb_A Active Member
    1,488
    yeah i get the irritating squeak!!! was going to post so interested in any ideas for a fix. i don't think the bolts, for me its plastic squeak when i rest my arm is on the arm rest. so.. any ideas :uhm: to get rid would be great
  4. owenjt
    owenjt Member
    118
    Mine used to squeak as it rubbed against the plastic backing of the drivers seat. I just bought some sticky back felt and attached it to the side of the armrest, no more squeak!
  5. sting3r
    sting3r New Member
    26
    Just been having a look at it, dont think its possible to stop it. Whatever angle i move, touch or poke the rest from, it squeaks. Its just the way all the bits of plastic fit together, its not actually rubbing against anything. Annoying, as its such a good feature and i wouldnt be without it.
  6. cloughy
    cloughy Member
    515
    If it were me I'd using a small amount of WD40
  7. rOb_A
    rOb_A Active Member
    1,488
    wd40 it be :idea:
  8. A3-8PA
    A3-8PA Member
    107
    use WD40... it worked on mine....
  9. Agent_Trig
    Agent_Trig Member
    552
    Where did you apply the WD40?
  10. leeroywarner
    leeroywarner Member
    52
    Know it sounds silly but I moved my seat 1 click and it stopped the squeaking for me
