Arm rest retro
philyus Jan 25, 2007
  1. philyus
    philyus Member
    30
    Has anyone retro fitted their A4 with a centre front arm rest? I am seriously thinking about giving it ago myself but am a bit reluctant. Everything reads like it is straight forward but has anyone actually done it that could give me a few tips? Even better than that anyone know someone who would fit it for me in the SE?
    Many thanks
    Phil
    06 A4 2.0T Quattro Avant S-Line SE Phantom Black Leather
  2. carjacker0
    carjacker0 New Member
    The proper retro kit is a doddle to fit as it comes with instructions and templates for where to drill and cut.If you can use a drill and small file you won't have any problem. The only problem you will have is thinking about what if i destroy my center console,even if you make a hash of cutting the holes the armrest covers everything so go ahead and get it done.You won't know how you managed without it after you do it.
  3. Sinny71
    Sinny71 S55 LKS
    779
    I'm just waiting for my retro fit armrest to turn up (albeit in a B6) so I can let you know how it goes when I install it. It certainly looks to be simple enough though.
  4. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    did mine last week,use the template and its very very very easy!
  5. philyus
    philyus Member
    30
    Is it easy to release the centre console and to get it back like new too? Knowing my luck I'll get it back looking like someone has tried to bodge it!
  6. Spin140
    Spin140 Well-Known Member
    2,196
    186
    How much for the retro kit ? 2005 model ?
  7. icenutter
    icenutter Member
    596
    Sorry if you know this already, but you have to cut a hole in the center console so returning the car to stock isn't possible. Or, at least, not without buying a new console...
  8. icenutter
    icenutter Member
    596
  9. philyus
    philyus Member
    30
    Thanks ice. Yes I was aware of that but do you not need to get under the console to attach the arm rest support? What I was referring to was how easy was it to get under the centre console and to re position/refit that when all the holes are cut etc.
    Thanks Phil
  10. icenutter
    icenutter Member
    596
    Ah. All you have to do is remove the ashtray and you should have enough access. You don't actually have to remove the centre console at all either.
