Areo wiper quick question
PaulJC84 Feb 28, 2006
  1. PaulJC84
    PaulJC84 Owner
    2,890
    13
    Hey guys i am needing new wipers and am going to just get the Aero ones i think.
    Just what to check where is the cheapest place to get them? Is the VAGparts site the place to go?
    Cheers.
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,116
    2,571
    It's where I got mine. You might find them cheaper elsewhere, but VAGparts are known & trusted. The service is very good, too.
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    german ebay, full set plus rear 80 euros
  4. Kevint
    Kevint Active Member
    1,182
    Jeff,
    Can you find your guide on fitting these please and post below, I'd like to add the thread to the FAQ.
    Cheers mate,
    Kev.
  5. jdp1962
    8,116
    2,571
    Here it it:
    1. With the bonnet up, lever the caps off and remove the retaining nuts with socket. Spray with WD40
    2. Whilst WD40 soaks in, unpack the new kit, inspect, assemble blades to arms.
    3. After about three minutes, with the bonnet down, remove the old wiper blades from the arms. This enables you to work on the wiper arm with the bonnet up again
    4. With the bonnet up , pull the arm back on the spring, & turn against the spindle. No need to give a sharp tug, just firm pressure, gradually increasing until the "seal" between trhe arm and the spindle breaks. Once it does, the arm comes straight off.
    5. Position the new arms and blades nice and low on the spindles, screw the retaining nuts on & refit the caps.
  6. jcb
    4,132
    13
    PLEASE ADD:
    DO NOT CLOSE THE BONNET TO GO FOR A CUP OF TEA WHILST THE ARMS ARE UP!!!
    YOU WILL BREAK THE ORIGINAL ARM AND DAMAGE THE PLASTIC MOTOR SHROUD UNDER THE SCREEN!!
    yeah, sounds a stupid thing to do, it is. I learnt the stupid way
