Are these B6 Aero wiper arms?
voteforpedro Dec 11, 2008
  1. voteforpedro
    voteforpedro Member
    632
    Got them from eBay a while ago but never used them because they're not a standard fitment.
  2. voteforpedro
    voteforpedro Member
    632
    Part numbers are:
    4B2 955 407 C
    4B2 955 408 C
  3. Siena
    Siena Active Member
    2,626
    Not B6 parts.
    B6 arms begin with 8E0.
  4. voteforpedro
    voteforpedro Member
    632
    Parts are 6a on the photo and the image shows an Aero wiper... but how do they fit?! I thought there's a pin which slides through the mounting point on the blade but these look quite different...
    ...Siena?!
  5. voteforpedro
    voteforpedro Member
    632
    Sorry, you're right - I meant A6. They were from a 2002-ish A6 and I found them listed under that model on Vagcat.
  6. Siena
    Siena Active Member
    2,626
    Hmm, seem different to mine.
    So the B7 ones have different attachment points, unless they're the same, and I can't remember.
    I bought both the arms and blades at the same time, and they were a doddle to mate together.
  7. voteforpedro
    voteforpedro Member
    632
    Thanks for your help. I might just take the arms down to GSF and see what they've got. Then go on eBay and get them for half the price. :)
    Cheers.
  8. voteforpedro
    voteforpedro Member
    632
    P.S.
    What do you do if the mounting holes are a different diameter? When I put some Mk5 Golf Aero blades/arms on my Mk3 Golf I just got the trusty Dremel out and made the holes bigger. :laugh:
    Probably not the best option since they're splined for a reason... but they worked nonetheless. :)
  9. Siena
    Siena Active Member
    2,626
    The B6/7 spindles are much, much larger than B5 ones, so the arms had massive holes.
    I had metal hollow cones turned to act as adapters, so the cones slid over the smaller B5 spindles, then the B7 arms fitted a treat.
  10. auroan
    auroan Active Member
    1,669
    If you want aero wipers for the B5, the easiest ones to get for fitment (as in no adaption what so ever) are Passat arms and blades
  11. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    they look the same as teh 8E arms I got from germany eBay
    As sienna says, needs cones.
    they sit too far up for my liking.
    wil check the part number
    Sienna, do you want mine so you can have two passenger side ones?
  12. Siena
    Siena Active Member
    2,626
    @ Jcb: Thanks, but I've already purchased an extra passenger side one.
    Just need to find time to transfer the old arm over to the new base, to retain a lower profile.
  13. jcb
    4,132
    13
    flared pin fitting isn't it. do you have to drill it out?
  14. Siena
    Siena Active Member
    2,626
    No, didn't have to drill out, as it's much larger than the B5 spindles.
    The adapters were made to "step-down" the larger items to match the much smaller shafts.
  15. voteforpedro
    voteforpedro Member
    632
    Siena - they look very similar to yours. I tried the O/S arm on and the holes are a fraction too big and they have that distinctive elbow I pointed out in the other thread. Either way, I don't like them so back on the 'bay they go. :)
  16. jcb
    4,132
    13
    have some adapter cones if you want....
  17. voteforpedro
    voteforpedro Member
    632
    Sorry, Siena, they look nothing like yours. :D
    I'm ill at the moment so excuse my stupidity...
  18. voteforpedro
    voteforpedro Member
    632
    Tempting... but I don't like the look so I'll wait until I find some B5.5 Passat arms. Out of interest, how much do you want for them?
  19. jcb
    4,132
    13
    £5 and I will post them to you for free ;)
  20. voteforpedro
    voteforpedro Member
    632
    Ooooh... how do you know they will fit? Tempting... let me find a price for a pair of blades and trial fit both arms and I will get back to you. :)
  21. jcb
    4,132
    13
    I know they fit because I ran those wipers for about a year before I swapped them for passat items.
    they are also conical so will fit most shapes as you tighten the nut.
    mine are brass.....
    bling
  22. voteforpedro
    voteforpedro Member
    632
    What are the part numbers of the Passat wiper arms? There are two listed on VAGCAT:
    Left: 3B2955409B and ...C
    Right: 3B2955410B and ...C
    Any ideas?
