Are these any good????
sherry Apr 16, 2008
  1. sherry
    sherry Member
    181
  2. alijames
    alijames Active Member
    1,024
    Absolute piece of cr*p. If you work out how much electrical power is needed to produce a decent increase in air pressure, bearing in mind, there is already a huge 'pump' in the form of the engine already sucking air into the cylinders, at the flow rates needed to supply a petrol engine, you would need a pretty damn big motor, and it would drain your battery in no time.
    A normal turbo anything up to 6-7psi, and a diesel turbo ~10-11psi
    I did see an article a few years ago where someone had built one which ran off capacitors, and could give a few seconds boost, but then would need a few minutes to recharge, so might be of benefit at a the lights, but that's about it.
    Check out
    http://www.turbomagazine.com/tech/0406tur_knight_turbo_electric_supercharger/index.html
    for a guy who tried it out properly...
    Don't waste your money.
    Cheers,
  3. sherry
    sherry Member
    181
    Thanks alijames.
    I had a feeling that was the case LOL.
    Another piece of rubbish that promises loads but doesnt.... (magnetic fuel savers LOL)
