Are Fault Codes timestamped?
crapo May 10, 2011
  1. crapo
    crapo New Member
    When a dealer connects to the car to check the codes, are the codes timestamped when they occurred? Also, as a matter of procedure, will the dealer record the timestamp when they download the code(s)?
  2. a8 tech back
    a8 tech back Member
    198
    depending on the edc year then yes ambient recordings record time date and frequency also type of fault is static (permanent) or sporadic
  3. crapo
    crapo New Member
    Sorry forgot to say 57 plate 8p (S-Line Quattro 170 PS TDi DPF).
    I got an MIL very shortly after buying a car from an Audi dealer but didn't take it in straight away as I was waiting for a replacement spare key and wanted it coding at the same time. It may be that the cause of the MIL is not covered under the warranty which if true, occuring less than two weeks after buying the vehicle, would be out of order. Just want some evidence as to how quickly it occured after buying the vehicle.
