Are all the ko4 TIP's the same?
Rice Jul 8, 2013
  1. Rice
    Rice Active Member
    247
    37
    Just about to sell my Forge TIP, it came off my S3 APY, just wondering if it fits all the ko4 1.8ts? I guess it also fits LCR's and TT's too?
  2. jojo
    28,881
    3,532
    No, there is ESP and non ESP versions, usually the ESP version fits APY/BAM/AMK, but earlier APYs with no ESP(like my car) is different, nothing lines up at all.
  3. Rice
    Rice Active Member
    247
    37
    Right ok thank you :)!
  4. JimS3
    JimS3 Active Member
    737
    72
    I recently fitted an SFS ESP hose to an early APY.
    The n75 pushes in the opposite side so the two wires need extending about 20cm. The hockey puck also needs about 10cm of 19mm hose to attach onto the TIP. Other than that it went on ok.
  5. Loor
    Loor Member
    32
  6. Rice
    Rice Active Member
    247
    37
    A mate has just asked me whether this will fit his ko3s.... Anyone know if it will?
  7. badger5
    9,469
    1,988
    no..
  8. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    The ko3/ko3s is a different setup and much tighter, the turns for the hose are no where near the same. Stick with the forge one if he is after one.
  9. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    Sfs supersize>Forge for K03.
  10. Loor
    Loor Member
    32
    Anybody knows answer to my question as well? :p
  11. jojo
    28,881
    3,532
    Instead of messing about with wires, I used an extended piece of silicon hose to plumb in the N75 on mine. Surprised you never went for the 80mm intake hose, it's proven to give 10-20bhp! I had mine rolling roaded with before and after plots, and was surprised it made a gain on a ten year old remap!
  12. Scullies
    Scullies Well-Known Member
    1,543
    657
  13. JimS3
    JimS3 Active Member
    737
    72
    Yes it might be easier to extend the n75 vacuum hose, but I like the oem arrangement of having the n75 in the tip, secures it in place nicely. + I work with electronics so quite used to doing a bit of wiring.
    It is the 80mm tip I fitted, the SFS version.
  14. jojo
    28,881
    3,532
    Fair enough, didn't know SFS did the 80mm ones too, good job.
  15. badger5
    9,469
    1,988
    some people do tho. tight yes, but the master cyl pipes are what will push into the pipe.. I guess folks just *cough* bend them a little bit out of the way perhaps
