Are 18" 5x112 pcd et54 standard for an S3?
wanton Jun 14, 2013
  1. wanton
    wanton Member
    234
    14
    Hi All,
    As the title suggests will they fit an S3? Is it the standard wheel size anyway? The S3 will be either 2009 - 2010 face lift if it makes any difference. Its the two piece 20 spoke alloys that were an upgrade on the S-line a few years ago now. Also think they were made by BBS but not 100% sure.
    Cheers!
  2. Lewbo
    Lewbo Well-Known Member
    1,266
    105
    Yes that's correct with a width of 7.5J, they will fit perfectly.
  3. Jonni
    Jonni Active Member
    256
    45
    Yep standard wheels are the above size
  4. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    886
    Sounds like the BBS split rims.....make sure they are mint and no corrosion around the bolt holes as its a nightmare to get rid completely
  5. wanton
    wanton Member
    234
    14
    OK thanks for the advise guys!!
  6. wanton
    wanton Member
    234
    14
    I presume £450 for a mint set is a good price?
  7. wanton
    wanton Member
    234
    14
    Yes mate, believe they are the BBS ones made for Audi.
  8. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,763
    354
    Pre-facelift wheels are ET56, facelift was ET54. The S-Line 20-spoke splits are either BBS or Speedline depending on age (iirc, BBS started as OEM then Speedline took over production).
