ARB rubbing on driveshaft answers?
Matt82 can you put up pics of your car please I want to see how low you are and what suspension are you running?
Matt82 Can you confirm what coilovers you are running and whether you droplink attaches to your strut or your bottom arm? Are you 2WD or 4WD? Pics of said set-up would be even better!
so with the audi tt front arb 20mm and bushes will resolve the rubbing dirveshaft issues(cheap option) ?
davea3 would it reslve the rubbing issues if the car was lwered 65mm n the front? cheers fr last reply
most likely. Fit it anyway as it means you can go lower at least. then check the clearance. Adjustable drop links might help it all depends on where you need the clearance. the tt arb fits underneath the driveshaft. At the moment ur standard one goes over the top and when too low it rubs
i cant unfortunately. try a search mate. Also damian has some has dpm performance. his link is in his post above ull find em. theyre easy to find on the site.
