  1. Madeley
    Madeley Member VCDS Map User
    125
    Anyone got one for sale?
  2. <tuffty/>
    21,784
    4,169
    Spotted one on ebay yesterday... about £250 ish IIRC...
  3. Madeley
    125
    i'll take a look, does anyone no if the amk is the same connection as the apy?
  4. <tuffty/>
    21,784
    4,169
    Fairly sure they are a different ECU... AMK introduced wideband lambda, VVT and a few other features... not sure if they are compatible... immo version may be different too...
  5. m4nj
    m4nj Member
    pretty sure i have one im me for details
  6. Madeley
    125
    The problem i got is i got a amk car with a apy engine in it , ive read the two heads have the same casting, so could i just fit the vvt to my head?
  7. <tuffty/>
    21,784
    4,169
    Right, with you now.... APY (IIRC) has SAI so you will need to blank that, swap the VVT/cam chain tensioner over too the APY head and all should be good...
    Only other thing I would advise if you are having to strip the head to to consider getting the exhaust guides replaced... these wear very quickly and so I have been told can contribute to valve failure...
  8. Madeley
    125
    Is it a head off job to fit the vvt? and whats a SAI? i'm a little green with this new tec, i did my yts on morris minnors:)
  9. <tuffty/>
    21,784
    4,169
    VVT is part of the cam chain tensioner and can be done with the head on... ideally requires a cam chain tool (about a tenner on ebay) and careful alignment of the cams but its not that difficult... there are a few guides kicking about on places like VW Vortex (I think I have linked to it a couple of times here but god knows where) so have a google...
    Secondary Air Injection (SAI) is a system used on some 1.8t's for emissions... the AMK/BAM S3's don't use it and it will be bolted to the gearbox side of the head if still there (by the plastic water housing) or may have already been blanked off...
  10. Madeley
    125
  11. Madeley
    125
    Any one got a second hand cam chain tensioner for a AMK for sale?
  12. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    No, no, no.....
    Don't get a second hand one dude. I know they are expensive, but installing a second hand one is a mistake. They never seem to work properly once they've been fitted and removed anyway to be honest.
    A new one at Audi seems to vary depending on where you go. Shop around.
    On the angine note, how have you ended up with an APY engine in an AMK car?
  13. Madeley
    125
    £350 new:faint:
    I have not had the car long and i'm finding all sorts odd things with it, like the wrong engine. its also got a screemer pipe on it, so god knows what turbo's in there!! next problem hehe.
  14. Welly
    10,696
    130
    A screamer pipe? OK, well it must have an external wastegate then for one to be fitted at all. So not a K04 as they are internally gated.
    Sounds interesting.
  15. Welly
    10,696
    130
  16. quattro1
    quattro1 Member
    639
    are u sure its a screamer pipe not just a blowy exhaust?? lol
  17. Madeley
    125
    Dunno!! i'll get a mirror in there and have alook tommorrow. It may just have a pussy cat stuck in there.
  18. Madeley
    125
    small update, got that cam chain tensioner off ebay, just got to fit it, is it a easy job? do l have to split the chain?
  19. Madeley
    125
    Put the new cam chain tensioner on yesterday, quite a easy job just a little fiddly. It feels like a new car, it now revs hard through all the gears. service, mot , tax and a remap next...yay
