APY bearings same as AYP
chaz20vt Dec 15, 2013
  1. chaz20vt
    chaz20vt Member
    428
    21
    Hi im planning on rebuilding my engine in the new year i have a 1999 Audi S3 APY, I want to replace the following parts......
    Rods (rifle drilled)
    Rod Bearings
    PistonRings
    Cambelt kit & Water pump
    Head Gasket kit
    Head looked at..
    Head Bolts
    Oil pump
    Oil pickup
    Obvious gaskets (that are needed)
    BBT Hybrid k04
    New Exhaust Mani (hopefully Badger one)
    550cc Injectors
    Relentless 3inch DP
    WMI (of some sort)
    Now my main question is I have a AYP bottom end which has had new bearings and piston rings fitted, It was started and run for around 2 miles.
    Would the bearings and Piston rings out of the AYP engine fit my current APY engine as there basically brand new.
    Or am i being stupid and should just buy new again????
  2. Broken Byzan
    13,237
    465
    same units, but depends on wear on your new block. Why not install the already done AYP bock ?
  3. chaz20vt
    chaz20vt Member
    428
    21
    As it has a oil leak on the craft seal...
    I was also hoping to leave my bottom end in the car....
  4. chaz20vt
    chaz20vt Member
    428
    21
    Any one able to give me some advice on this?
  5. Gops
    3,198
    666
    I'd fit new ones mate. Pistons might be ok just check there's no damage. But bearings should always be new and never transferred IMO. The wear may be different and you never know, could lead to disaster!
  6. Gops
    3,198
    666
    Change piston rings too.
  7. chaz20vt
    chaz20vt Member
    428
    21
    So the rings and bearings from the AYP which have only had around 15-20 mins of running time (so i should tink not run in)are no good to use again????
  8. ManuGD
    ManuGD New Member
    24
    I wouldn't say that they are not good, you can use them again, but new ones would always be better.
  9. limbo118118
    limbo118118 LORD
    503
    53
    for what its worth id just buy brand new again, saves anything going wrong and having to strip it all down again..
  10. chaz20vt
    chaz20vt Member
    428
    21
    Ok thanks for that. ..
